Wish - Request / Show curves in yellow when you construct it.
All  1-5  6-8
1537.6 In reply to 1537.5
Well it's really hard to see the curve between the first two bottom points here, probably the gamma is different on my pc.
But yes I see some dashed lines, I just need somethink a little bit more clear.
>It would mean that you wouldn't get the full depth perception of the curve and how it related to other objects in the scene until you finished drawing it...
>But yes I think that getting a clearer view of the curve you are drawing is more important
>I think I can set it up this way for v2.
Great :)
1537.7 In reply to 1537.6
Hi PaQ,
Yeah, that part can get washed out on certain displays. It is possible to adjust that to make it darker if that would help for now.
To do that, make sure MoI is closed and then open up the moi.ini file in notepad which you can find here:
C:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
Find the [Hidden lines] section, and there is a setting:
[Hidden lines]
HiddenLineOpacity=34
That can range from 0 (no opacity = fully transparent) to 255 (fully opaque).
Maybe something like 75 or so would improve the hidden-line display on your system.
That may be useful for you before this is ready for v2.
1537.8 In reply to 1537.7
thanks for the tip !
Show messages: All  1-5  6-8
