Wish - Request / Show curves in yellow when you construct it.
All  1-2  3-8
1537.3 In reply to 1537.2
A color for line under construction would be good (if possible).
- steve
1537.4 In reply to 1537.2
Hi Michael, I completely get your point, yellow mean active and it's a bad idea ...
but I still thing there is something to do because like I show in the second exemple, you just see nothing of the curve you're drawing when there is some geometry in the viewport, and it's quite disturbing. Maybe it's possible to force the z-buffer to draw the curve in the front of everything during the building, even if the curve is inside an object you can still see it. It's how it works in rhino too. (sorry to compare always with rhino ^^ it's the only other nurbs modeler I have installed here)
EDITED: 3 Dec 2015 by PAQ
1537.5 In reply to 1537.4
Hi PaQ,
It shouldn't normally be the case that you see nothing of the curve - you should be able to see the curve displayed in the dashed hidden line style, you can see this in your own screenshot above.
This is certainly possible - it would definitely be a more natural fit than showing it as selected.
It would mean that you wouldn't get the full depth perception of the curve and how it related to other objects in the scene until you finished drawing it... But yes I think that getting a clearer view of the curve you are drawing is more important
I think I can set it up this way for v2.
1537.6 In reply to 1537.5
Well it's really hard to see the curve between the first two bottom points here, probably the gamma is different on my pc.
But yes I see some dashed lines, I just need somethink a little bit more clear.
Great :)
1537.7 In reply to 1537.6
Hi PaQ,
Yeah, that part can get washed out on certain displays. It is possible to adjust that to make it darker if that would help for now.
To do that, make sure MoI is closed and then open up the moi.ini file in notepad which you can find here:
C:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
Find the [Hidden lines] section, and there is a setting:
[Hidden lines]
HiddenLineOpacity=34
That can range from 0 (no opacity = fully transparent) to 255 (fully opaque).
Maybe something like 75 or so would improve the hidden-line display on your system.
That may be useful for you before this is ready for v2.
1537.8 In reply to 1537.7
thanks for the tip !
Show messages: All  1-2  3-8
