Booleans
 1-5  6-25  26-34
1524.6 In reply to 1524.5
I then I go quite mad!
EDITED: 30 Dec 2008 by BWTR
1524.7 In reply to 1524.6
Brilliant light :)
1524.8 In reply to 1524.6
Sorry, I got called out. But it looks like you worked out how I made it.
I will play more with this.
1524.9 In reply to 1524.8
More booleans:-
EDITED: 3 Aug 2009 by MANZ
1524.10 In reply to 1524.9
Forgot the render:-
1524.11 In reply to 1524.10
Manz
I am not sure I did my work the same way as yours. Any brief summary of your work flow would be welcome.
AND NOW! you are going to make me (try to) puzzle out how you did this last one all day!
1524.12 In reply to 1524.11
The first model is just lots of spheres,
I started with a large sphere for the internal rad,
I then added a small sphere, snapping on the int of the outside of the large sphere.
I cut off the top of the small sphere, then boolean away the large sphere (I made copy of large sphere to clipboard so I could paste back for later booleans), which left me with:-
I then made circular array of the cut sphere:-
I then placed a sphere at the int of 2 of the spheres:-
I then pasted back the large sphere to boolean away from the new small sphere:-
Then back to making array, then just repeated that until I got to the bottom (where I wanted the base to be). Then made boolean union of all the spheres, then added a base.
That is basically it.
I hope I have made it understandable?
- Steve
1524.13 In reply to 1524.12
Thanks mate.
Somewhat different to the way I approached it. I think yours is easier and has better precission and will try it soon.
But that last vase is really driving me mad! Would you give a proceedure for that--perhaps tomorrow!--better if I keep on struggling for a while as then I learn more.
1524.14 In reply to 1524.13
Steve
(First method)
Having some fun relating to your little tute principles.
(REALLY need info on the dooing of the second one though!)
1524.15 In reply to 1524.14
Looking good there.
I will point you in the right direction:-
If you look at the image in post 9, you will see that it is in 12 sections. So, I first created a plain dish/bowl, I made boolean cuts (with lines) to leave me a 12th of the bowl (30 deg) I then created a curve to boolean off the top rad, then created the pattern in 2d and projected to surface. On the projected surface lines I made pipes, that I then boolean out of the surface, I then made circle array with that section, and boolean them together to make the full bowl. I then made fillet around the top edges.
I hope that helps, if not, I will post some pics with a better explanation.
I have started another bowl, this will have much more etching, I have just got to making a nice pattern on the top edge, but MoI is taking a long time in calculating.
up to now:-
1524.16 In reply to 1524.15
Steve
My mind is working overtime-----will ponder on all that and be back-------well,---later!
(What great mental fun!)
Brian
1524.17 In reply to 1524.16
As you can see Steve, I am learning!
Still need a bit of instructions on getting fine "etching" on multy curved faces though!
Thanks for one of my GREAT learning days.
Brian
1524.18 In reply to 1524.17
For the etching, you need to project to surface.
As with the example, at the stage of when you have just the one section, draw the pattern you want to cut out of the surface, make sure it is from one of the main view (it just makes it easier).
Then in the example, I have projected (curve~ project) in the right view onto the outer surface
Then its just a case of creating a pipe (whatever size you want) onto each projected curve,
The boolean them out.
1524.19 In reply to 1524.18
I forgot to mention. If you use sweep on the projected lines (sweeping a circle for example), then you can select the "pointy ends" option which can give some good results:-
How simplicity can be be make some beautiful forms!
1524.21 In reply to 1524.20
It's 6.15 pm. I guess I best leave that new fun for tomorrow.
Thanks.
1524.22 In reply to 1524.20
Well I could not rest untill I had tried it out!
1524.23 In reply to 1524.22
Looks good.
Just be cautious of overlapping tubes/pipes on the surface when making boolean as I have seen some problems.
First one can be seen on simple boolean of 2 tubes at angle:-
Made boolean union, with result:-
The workaround for the above is to make the pipes different sizes (even is only by .001)
I have also seen problems due to where the seam of the pipe is in relation to the surface. I will have to find good repeatable example to show.
- Steve
1524.24 In reply to 1524.23
Thanks Steve. It was some good learning exercises.
I can not duplicate that boolean problem?
Can you explain specifically how you had it happen? I tried all sorts of angles without problems.
Brian
1524.25 In reply to 1524.24
Strange,... OK, I will look at my setup, with possible re-installation (of OS if needed).
I did play a little more, and made booleans to produce:-
But have not rendered it yet.
- Steve
Show messages:  1-5  6-25  26-34
