Another alternative UI
 1-14  …  55-74  75-94  95-98
1521.95
-Hi Ed, well I guess with a system like that you would be looking at setting up some dozens or maybe hundreds of default keyboard shortcuts right out of the box.
-MoI's shortcut key philosophy is sort of opposite of that - it's more like letting you set up shortcut keys that personalize things to how you may want to do things with only a pretty small number of defaults.
Well I think thats great but one thing i thought is that you can let the users assign one shortcut to a group of tools inside the options panel.
Think of having a window where you assign one key (like right now) but instead of being limited to add one tool to that key, you can (for example) clic a plus button and add another tool below to that same shortcut key and then when using it, the tools behind that shortcut will cycle in the order you added them.
Currently i have the left side of my keyboard full of shortcuts for working with the left hand in the keyboard and the right hand with the mouse, but even if I use all the keys in my keyboard, they will not be enough for all the tools i use often. Actually I almost use all the tools you have put inside of MoI and more that i have in my plugin gallery.
I think for enhancing the shortcut system and preparing it for all the new tools you plan to add, this cycling solution can be a lot better than having a more-than-one-letter shortcut system and having to press enter or spacebar for activating each shortcut. It will be more intuitive too.
1521.96 In reply to 1521.95
Hi Ed,
That's a pretty elaborate UI that would be specific to just this one particular "cycle between tools" use.
Rather than some special UI for just that one particular purpose, I'd rather let you just pick one action for the shortcut key similar to how you do now, but that action could be a script that contained whatever logic you wanted in it, including cycling between tools.
Basically once I add the ability to retrieve the current running command for a script, it should then be possible to have a script that will do this kind of cycling without having any special setup UI like what you're describing now.
Eventually I want to make it easier to assign a script to a shortcut key, something like letting you connect to a list of named scripts so you wouldn't necessarily need to see the actual script code itself in that dialog, you would just pick something named like "Cycle between line tools" for the keyboard shortcut for doing that kind of cycling stuff.
The thing that's good about this approach is that there is a tremendous amount of flexibility in what you can do in a script - it can do all sorts of combination of actions like do a view reset, and also switch to the next tool but only if you're over a certain viewport, or anything like that, far beyond just simply switching between 2 tools.
So for improvements in the shortcut key editor, I'd really be looking more at making it easier to pick a script for that shortcut key from some kind of script library, and that script library could contain all kinds of stuff including tool cycling as well.
1521.97 In reply to 1521.93
Thanks mjs & sw03!
I don't know if this will be alive anytime soon since as Michael pointed out, he is still working on the release
and things are subject to change.
I will still try to work on some of the ui icons during my free time.
Maybe when the system is more stable I can push something out.
In the mean time, I'm just laying things on my head and pondering about the elements and interactions I'd like to
see in my idea of an ultra simple and elegant minimal ui. :)
I think Michael has taken great strides in that direction. Certainly inspired me with Moi. :)
I'll keep you guys posted.
-Luis
1521.98
-So for improvements in the shortcut key editor, I'd really be looking more at making it easier to pick a script for that shortcut key from some kind of script library, and that script library could contain all kinds of stuff including tool cycling as well.
I like that!
Show messages:  1-14  …  35-54  55-74  75-94  95-98
