Another alternative UI
 1-5  6-25  26-45  46-65  …  86-98
1521.6 In reply to 1521.1
Hi Tony, I'm glad you are having fun with the UI toolkit!
A lot of nice little details in there, I like the eye icon and the [ ] grouping brackets in the view control areas.
It looks like you have really gotten the hang of all the mechanisms that make up the UI.
1521.7 In reply to 1521.3
Hi Val,
> honestly, the only thing I want to see different from the
> current user interface is the ability to pull out tabs, <...>
You mean like drag on a tab to kind of "undock" it and then drop it somewhere else?
Unfortunately accomplishing that it a really big area of work. I think it would be great to have it, but it is hard to schedule the time to do it very soon since it is so time consuming. Right now I am doubtful that it will fit into the v2 schedule.
There was an older discussion here: http://moi3d.com/forum/index.php?webtag=MOI&msg=844.1
about editing the UI just to separate out those toolboxes, I think there is another alternate UI in that thread that has that set up.
But for future scalability it is pretty important to have a system where it doesn't have every single toolbox displayed all at once by default. In the future I will be adding a bunch of additional tabs over there, and if it was just all single expanded toolboxes all the time, it would run out of space pretty quickly and not really scale up to have many more toolboxes.
So that's one big reason for the current system - it is much more "future proof".
However, I have made an attempt to try and put some different kinds of tabs on each row to try and minimize the amount of switching that is necessary. That's why for example Draw curve and edit are not on the same row.
Are there a few specific tools that you find yourself needing to switch between more frequently than anything else? If so, please let me know about that, there are other things that I can do to help out in certain circumstances. Like for example I do want to add a kind of quick editing frame to handle scaling and rotation right inside the viewport without needing to go to the transform tab all the time for that. If I knew about other frequent "switchers", it would help me to think about other possibilities to bring some of their functionality out in other ways as well.
I also want to have a method that lets you drag out a particular command that you might use frequently and place that on the bottom toolbar in a kind of custom toolbar area (between Object Snap and Options). This is probably something that will happen before a full blown palette drag/drop, but I'm still not sure exactly when.
It is possible to edit the UI files to place a particular button in that area right now, let me know if you would like more information on how to do that.
1521.8 In reply to 1521.7
I like the UI with as much as possible on the right hand side.
Similar to the one given me by Michael on a thread recently.
I only need the manipulators to be on the RH side(vertical) as maybe coming as an option in V2?
1521.9 In reply to 1521.6
Thanks for the comments people. I made this partially because I wanted to see how far I could get and also I always like customizing the interface. For V2 I would also really like to be able to detach the palettes (tabs?). I have a whole second monitor that I use for palettes for photoshop, etc. that MoI can't use at the moment.
Thanks Michael. I'm no html expert though - I just kept trying things until I figured out what did what. Managed to cause a few errors along the way but nothing stopped MoI loading.
>>What I dont understand is why the scale array is not where the
>>other array tool is....?
I put it there because, in my mind, it isn't really an array. It's a tool you use after you made an array. Made sense to me ;-)
>>For example Select tab with additional commands from Tony could be under one button, like Boolean etc
I tried to make this but failed to get it working properly. Also this makes for an extra click which I didn't want so I gave up and left them all available. I find myself using the select all curves one quite a bit.
Tony
1521.10 In reply to 1521.5
Hi yannada,
>>>I have to keep switching between tabs in order to get to the tools and that gets confusing
I have changed my layout that does remove the tabs, (the commandsets are still in place on this version, so when I click on "line" for example, it does then open out to the option of line/polyine)
I have on this version placed all commands out into view (no commandsets, no sub options)
image trimmed~ not showing all commands
EDITED: 3 Aug 2009 by MANZ
1521.11 In reply to 1521.10
Manz
This is great idea - did you use just one tab or no tabs at all? Can't quite see on the image.
Tony
1521.12 In reply to 1521.11
Hi Tony,
There is a need to place a tab (just one at the top), but I did not name it, so the tab is there (and can be clicked) but it is very thin (so not easy to see)
1521.13 In reply to 1521.12
Thanks manz.
Tony
1521.14 In reply to 1521.7
Thanks Michael. I didn't know that it would be a lot of work. Something else like creating a custom palette will work just as fine. The tools I find myself using most frequently after edge tools are boolean operations and surface creation tools in one tab and then scale and mirror on the other. I got some hot keys set up, but the problem with scale is that it has more options and the hot key will use the last used setting, so it is necessary to switch sometimes.
Thanks!
Val
1521.15 In reply to 1521.14
Hi Val,
Could you please elaborate a bit on this one - for the regular Scale command there is just one "Make copies" option... Is that the option you are referring to here? Or are you talking about the difference between the 3D / 2D / 1D scaling commands?
If that "Make copies" option gets in your way, you can actually skip setting it by instead holding down the Ctrl key when you click the final point for the scale, that is an alternate way to drop a copy without setting the check-box.
But definitely simple scaling and rotating are things that I want to enable by a kind of "in viewport" type grips which should really reduce needing to open up the Transform tab so much.
You can get a feel for how I think these will work by using the current View/Image command to insert a background image - while you are in that Image command it will have grips just outside the corners of it for scaling, and also one for rotation as well.
1521.16 In reply to 1521.15
I hope you plan to leave the existing scale commands as well. I love the way they work.
Tony
1521.17
Me too !
i like the way they work !
Much better then the eyeballing in some other programs !
Peter
1521.18 In reply to 1521.16
Hi Tony,
Yup, that is the plan - the existing scale and rotate commands will stay exactly as they are. The existing ones will have some advantages for precision work since they can snap on to reference points in the model for exact measurements and also take specific numeric input.
The idea for the other ones will be for doing quicker more just mouse-driven type manipulation.
1521.19 In reply to 1521.15
>>>But definitely simple scaling and rotating are things that I want to enable by a kind of "in viewport" type grips....
I would agree with Tony,....... but think you would leave current scaling (and move/ rotate) in place anyway.
I know having onscreen (widgets) manipulators can be good and save some time if they are implemented well. I see the "widgets" in many 3d poly modelers and they can be a complete pain at times, as they can become hidden/ off screen, I usually end up disabling them.
So if you do implement such a feature, could you please make it an option, so I can disable if wanted.
- Steve
edit:
Sorry Michael, you replied already.
1521.20 In reply to 1521.18
Great, thanks Michael
Tony
1521.21 In reply to 1521.19
Hi Steve,
I will also make it possible to disable it entirely if you want.
But I will be putting quite a bit of effort into making it as unobtrusive as possible.
To start with it will probably only be applied to 2D shapes and function more like a 2D illustration kind of bounding-frame widget rather than the poly-modeler type manipulators.
1521.22 In reply to 1521.15
Yes, I am talking about the 2D, 3D scale options. And what a adding a viewport navigator would be good for basic stuff, but I am not sure how you can make it more advanced, like for example I use a lot the guide lines to find centers, coordinates, and so on to scale or rotate about, or to move objects to some relative point in space and so on.
1521.23 In reply to 1521.22
Hi Val,
> but I am not sure how you can make it more advanced <...>
I have a few ideas... It may be possible to do something like bring up extra options or controls for certain actions like a click and release on a grip instead of a click and drag.
That might flip it between some different kinds of modes that have more draggable points within in the widget (like for an origin point for example). It's a possibility anyway.
You can see an example of this in the Image widget frame currently - if you click and release on the rotation grip there, it will switch to a tri-ball rotation widget that lets you rotate around any of 3 different axes instead of only rotating in the plane which is what happens when you drag directly on that rotation grip instead of click on it.
But I don't really have all that completely nailed down yet though.
At first the primary focus of this will be just for simple stuff, since the Transform commands cover the precision stuff well already. But it would certainly be nice if it could incorporate more advanced transforms as well.
1521.24
Although I only purchased MOI about a week ago (and am delighted with it by the way!), I have been intrigued by this thread, and being a bit of a 'fiddler' have been having a go at making my own changes.
Modo is my other favourite 3d app and I like its darker theme, so here is my attempt at producing something similar. I've based it on the UI provided by Tony (aka Ash) in this thread as I like its layout and the additional tools, but have darkened it down some what. I have attached a screen grab ... What do you think?
The modified files are in the second attachment.
1521.25
Oops! ... just noticed that there in not enough contrast in the numeric input panel. This replacement UI zip fixes it .
Show messages:  1-5  6-25  26-45  46-65  66-85  86-98
