Merge edge
All  1-7  8-9
1518.8 In reply to 1518.5
Hi Steve,
> For the curves, that would be equivalent to the "match" command
> in Rhino, so would there be sub_options, such as "continuity"
> "preserve other end"?
I guess so... I haven't quite figured out if all of "Merge" and "Match" should be all combined together or not yet.
In Rhino just from the way things pieced together, there is a MergeEdge and MergeSrf, but no plain "Merge" for curves... Then separately there is Match for curves, and MatchSrf for surfaces.
It might make sense in MoI to have this boil down to 2 different commands - Merge that works on curves (no continuity options, just makes it one fully smooth segment), edges that are tangent, and surfaces, and then a Match (with continuity options here) that works on curves and surfaces for editing their shape but keeping them separate objects...
If it is all combined into one single command, it will be difficult to label the MatchSrf functionality because editing a surface to make it smooth to another one does not really fit so great with the term "Merge".
1518.9 In reply to 1518.8
Rhino will not allow the merging of lines/curves unless the curvature is correct, that is why the option to merge curves is a sub_option of match.
I think it could be a little unpredictable to have a Merge that is going to adjust both curves automatically, but I will wait and see what you come up with.
- Steve
Show messages: All  1-7  8-9
