Massive joining
 1-14  15-33
1497.15
Hi Michael !
Heres a file ..... would be great if you would just show me how to do the flower .
I have done a few tests with booleans and merge and the join etc.
sort of dont get a whole mesh .... always just the outlines or not joining rings....
pretty difficult !
Thank you very much Michael... !
Peter
1497.16 In reply to 1497.15
Hi Peter, curve booleans will focus on forming closed loops.
In the case you've got there, your pieces are overlapping in enough areas to create several closed loops, like here are 2 of them:
The booleans don't know to give any special importance to one closed loop over another, so you will get them all - the above result was from boolean union applied to the curves.
If you want a different result than this, you can use Edit/Trim to gain more exact control over what pieces to remove.
Here is the procedure to use Trim - first select all the pieces:
Then run Edit/Trim. In the upper-right area of the screen it will display a prompt for "Select cutting objects or Done for mutual trim".
In this case you don't need to select any other cutting objects, you want all pieces to both be cut and to cut the others. So for this stage you don't pick anything and just push Done (or right-click in the viewport).
That will then cut all the pieces up and the various fragments will be displayed, it should look like this:
Now you can select which pieces you want to remove. In this case you want to pick the inside pieces (if I understand your goal correctly).
It can help to do window selects to pick several pieces in one action. Like in this case you can grab everything by one strategic window starting in the upper-right corner and dragging down to the lower left, like this:
You can also just click individually on the pieces you want to discard, and you can also switch the Mode: option to Mode: Keep and click on the pieces you want to keep instead of the pieces you want to discard.
After you are done picking the pieces to discard, push "Done" or right-click and this will be the result:
Now you can select those pieces and use Edit/Join to glue them into a single curve if you want.
If your curves have a lot of criss-crossing areas, you will need to do this kind of trim operation to cut away the specific pieces that you want.
I hope this helps, and please let me know if you have any problems following these steps!
1497.17 In reply to 1497.15
Hi Peter, one other note - if you had your original curve that you arrayed to be shorter and not end up criss-crossing over top of itself so much, like this:
Then it would be possible to select all these pieces and do boolean union to get this result in one go:
So keeping the kind of "excess" pieces down in size somewhat can make things easier as well, if you want to use curve booleans.
1497.18 In reply to 1497.17
A very speedy method is just draw one Half petal
Mirror for have one petal
then do an "Array Circular" ;)
and the Boolean union (like above) if not fit on the extremities
EDITED: 26 Mar 2008 by PILOU
Size: 31.6 KB, Downloaded: 52 times, Dimensions: 425x390px
1497.19
Hi Michael !
You missunderstood me I´m not after this simple shape thats pretty easy....
Its this what I´m after...... I want to make some fences and fence like shapes.
I didnt manage to do the last step to boolean all together but I found
out that for big things to join together I can now use Vue 6 inf.
to make a whole out of the pieces.
Would be nice in Moi 3d V2 to see a merge option upon export (obj. format)
I enclose the merged obj. that came out of Vue and the non meged 3dm
Peter
1497.20 In reply to 1497.19
Hi Peter - I see... In that case I would recommend these steps:
Start with one petal:
Use Construct / Offset and draw 2 lines + join them to make a thickened curve:
Now use Transform / Array / Circular:
Then select all these pieces and run Construct / Boolean / Union, that will fuse all these closed curves together, resulting in this:
This can now be selected and extruded:
If you get a more chaotic situation with quite a lot more pieces crossing over top of each other, then you may need to use the Trim method that I described earlier to finish up the 2D outline.
Basically any time that a boolean can't figure out how to finish your piece, you should be able to accomplish it by using Trim instead (with some more labor involved for picking the pieces to discard).
But definitely with a complex thing like this, I would recommend focusing on producing a full 2D pattern first, and not getting into 3D until the 2D pattern has been all completely finished up.
By luck I just happened to post an OBJ merge utility just a couple of minutes ago here: http://moi3d.com/forum/index.php?webtag=MOI&msg=1499.3
1497.21
Hi Michael !
Thanks this is the easiest !
Your Merger tool works great !
Thats what I was looking for........
I tried it on the mesh and it works ......fantastic.
The other option is good too.
But I have some 3 dimensional objects that I produce with lots of arrays
and the tool works better with them then making 2d first.
Would be fantastic to see the application built into Moi3d !! : )
Peter
1497.22 In reply to 1497.21
Hi Peter, well there is a difference between the methods.
That tool just combines all the polygons together into one big object - this leaves a bunch of polygons on the "inside" part of the mesh - it basically does not generate an object made out of one single connected skin.
In other words, it is not a totally clean single volume.
For some purposes like rendering where you aren't looking at the inside that is not a big deal. For other purposes like manufacturing, this kind of messy interior is a problem.
The 2d method would create a completely "clean" volume without extra pieces hanging around on the inside of it.
1497.23
Thanks Michael !
I understand that ...
If this would be implemented it should only be as
an option with a check .
Its usefull in most cases to have seperate object pieces for texturing
in other cases its easier to texture in one go !
Manufacturing is another pair of shoes : )
Peter
EDITED: 26 Mar 2008 by RAYMAN
1497.24 In reply to 1497.23
Is the previous OBJ utility added on the Wiki?
Little precision of word!
it's the "Boolean Union" tool
not the "Boolean Merge" tool !
1497.25 In reply to 1497.24
Not yet - I'll add it up there tomorrow though.
I think maybe he was referring to that MergeOBJ.exe utility here instead of booleans?
Maybe :)
1497.27 In reply to 1497.26
Yes !
Thats what I tried out and it worked great !
I did not speak about the boolean tools they are great too ....
but thats what I started out with ... and had the problems with !
I have so many occasions were this tool is usefull.... ! :)
Peter
1497.28
I've noticed in MOI that at times when I can't get a join or a union to work with something, if I explode everything and then join/union piece by piece, I can then get everything joined together as desired...
-Will
1497.29
Just wanted to publicy thank you Michael for the GREAT support, your joining fix completely fixed the problem and I just joined a 400MB object made of hundreds patches successfully, and in a really short computation time (rhino failed here).
Thank you very very much.
Erwan
1497.30 In reply to 1497.29
massive attack :)
1497.31
Massive thanks !
Peter
1497.32
btw, sorry to get back again and again on multithreading :s
but couldn't MoI use one thread per object when doing such operation ?
1497.33 In reply to 1497.32
Hi Erwan - well the way joining works is not so much on a per-object basis as it is a processing of all the open edges.
The tricky part is that also some edges may be modified during the join process, for example when 2 are glued together, or when an edge is split into multiple edges.
Algorithms that do modifications in the middle of them tend to be more difficult to break apart into parallel tasks that can be handled by multiple threads.
The other thing is that something like "one thread per entity" really doesn't work very well, because that actually creates too many threads to be optimal - to make best use of resources there shouldn't be more threads than CPUs. So the way it usually needs to work is to maintain a kind of queue of work items and parcel those work items out to be processed on different threads.
It is not typically a very easy task to take a chunk of existing code that is not built with this in mind and then change it to do that... It tends to require a significant rewrite of the code, not just a minor modification.
Show messages:  1-14  15-33
