Is there a way to change the default input/interaction for Revolve?
Currently it is a case of "select curves to revolve" then (basically) a single option for the angle/center. As when you select the center_axis the revolve is made.
I would ask (if possible) for the ability to "select curves to resolve", then "select revolve axis", then an interaction for the angle (as example, we see for the creation of fillet/chamfer.)
To push such a request further, maybe a start/ end angle?(on_screen interaction by mouse) This maybe more a case for version 2 (if not possible by scripts in current version?)
Regards,
Steve
Edit,
Forgot to mention, I notice that currently a negative value cannot be entered, so revolve is allowed in only one direction, so could direction be added at some time?
