Some help with network
All  1-11  12-18
1484.12 In reply to 1484.8
Hi contact7 - Steve shows the way the curves need to be arranged.
In your current arrangement, the pieces at the end don't form a complete 2d grid - for example:
Imagine if you had longitude lines on a map - you wouldn't have 2 longitude lines like you have there - one of them there is too short and does not traverse the full extent of the "map".
For it to work, you need to have a layout where each of those longitude lines crosses over the same number of latitude lines.
1484.13 In reply to 1484.11
Hi contact7,
> Are there any specific guidelines when working with networks, or
> is it just experimenting?
The guideline is that your curves should be arranged so that they have a 2D grid type arrangement to them, the same kind of thing where latitude and longitude lines on a globe of the world form a grid that can be re-arranged to a 2D rectangular map.
Each of your longitude lines should cross over the full set of latitude lines.
> For me, the method I tried looked reasonable (but I'm a MOI newbie).
Visually it looked good, but the actual arrangement and sizing of the curves at the ends there did not make a "formal" grid layout (shown above with that small piece not matching the rest of the grid).
Unfortunately MoI needs the curves you give it to definitively form a regular grid pattern, it isn't able to handle it if your curves visually look similar to a grid but need some re-arranging (including merging or splitting pieces) to actually form a true grid.
I hope that helps!
1484.14
Just out of couriousity.... what do you need the second
set of longtitudinal lines for in the first place ?
Network does very well construct without them b y using the form
of the latitudinal lines... see this...
1484.15
Hi Rayman. I said I was a newbie, didn't I?
Well I kind of followed "The more, the better" rule.
Michael thanks again for your comments. I see what you mean now. Mine looked like a 2D grid , but in fact it wasn't.
Anyway, I'm improving bit by bit. So here's what it looks like right now.
One question. If a have a curve like the one shown below, with a lot of control points. Is there a way to reduce the number of control points while retaining the actual shape?
Mark
1484.16 In reply to 1484.15
Side tracking I know, but here are a couple of renders from my first MoI Mouse!
(Do you need to see the HUGE folder containing all my learning efforts?--but what fun!)
EDITED: 31 Dec 2008 by BWTR
1484.17 In reply to 1484.15
Hi Mark,
Removing control points will change the shape, although it may only be very slightly (depending on the gap left between the adjacent control points). Removing control points is a way to refine the shape/surface, as MoI will give to real_time feedback and show the change when a control point is removed.
- Steve
1484.18 In reply to 1484.15
Hi Mark,
There isn't any automated "rebuild" type command in version 1.0 .
If you want to make a big change in the point structure, probably the best method right now is to draw a new curve and use the old one as a snapping guide to make it follow the general shape.
Show messages: All  1-11  12-18
