Hidden line snapping
All  1-6  7-11
1471.7 In reply to 1471.6
The best way for 3d snapping IMHO is the use of working planes instead of layers.
If I can snap only on selected faces it will be more simple to snap correctly, simulating the use of planes.
Snappin in the 'volume' is quite difficult and may be better to snap using the ortho views and passing from one to another (with LMB on).
Gianrico
1471.8 In reply to 1471.6
Hi Steve,
> That is what I have been doing, but I was thinking that after
> you select an object, then "hide", that on the second press of
> hide that the selection would reverse, what I would of thought
> as an easy option to "hide all not selected".
I can see how that would look like that.
But what actually happens here is after the object is hidden, then nothing is selected.
When nothing is selected and you push the "Hide" button again you trigger the regular show mode, same as if you pushed it at any time when there are no objects selected.
To do a "Hide all not selected" (sometimes called "Isolate selection", etc... ) is a different thing, you can do that by setting up a shortcut key with this script on it:
script:moi.geometryDatabase.invertSelection(); moi.geometryDatabase.hide(true);
> Is there a way to inverse selection? So I can select a few objects,
> inverse selection, then hide.
Yup, there is a button for this Select menu on the right-side pane. If you want to set it up on a keyboard shortcut, use this:
But if you want to do this frequently you may want to use the other script above which bundles the invert and the hide all together.
1471.9 In reply to 1471.8
Many thanks, that was just what I was looking for.
Regards,
Steve
1471.10 In reply to 1471.5
>>>I have added this to the wiki wishlist to keep track of.
After the options you have now shown (via scripts) I actually see no need for this. I would therefore ask you to remove this request (unless other have/do ask) I would prefer you to spend time on what is actually needed.
Regards,
Steve
edit:
PS
Layers would be nice.
1471.11 In reply to 1471.10
Hi Steve, I have already thought about it a little bit, and I think I may have a way to make it work while avoiding the overlapping type problem that I was talking about.
It turns out that the new method that I have planned is not too terribly difficult to achieve, I think I should be able to give it a try in v2 without really disrupting other work.
I'm not 100% sure if it will work out or not but I would like to give it a try and see...
So there is a good chance that this may come along anyway.
Layers / organization type tools are definitely going to be a big focus of V2 though. But that's going to involve a significant new piece of UI and will take a fair amount of time to complete. I will probably chew on it pretty early in the v2 cycle though.
Show messages: All  1-6  7-11
