Exporting from MoI to other 3D programs
All  1-16  17-20
1465.17 In reply to 1465.16
Hi Alphapack - I believe the Maya Personal Learning Edition does not have the full set of file support that the regular Maya version has.
One thing that should work is export from MoI to .3ds format, then use the 3dsin command in AutoCAD.
Does that do the job for you?
Another possibility is to export from MoI to .obj format, using the "Output: Quads & Triangles" option, then use a converter program like 3DWin to convert it into DXF format, which is supported by AutoCAD as well. 3DWin supports a lot of formats so with this method I would think you should be able to find something in common with your other programs.
1465.18 In reply to 1465.15
Hi Gianrico,
> Ok Michael, away from me the idea to ask fixing something for me!
Well, the true fix in this case would be for MoI's IGES reader to look at the group elements in the IGES file and only attempt to join surfaces from the same group.
I would like to fix this in the future, I have added it to my list of stuff to work on.
The other part that you are asking about, the disconnected object, is related to difficulties in processing the big pile of surfaces with coincident edges. Even if the area is not immediately in the same spot as the coincident edges, it is caused by side effects from those in other places of the model.
Are you able to use one of the methods above to get this model finished up properly?
Let me know you if you need any help finishing this, I could do one of those steps for you and send you the completed model if you are having difficulty finishing this up, just let me know.
1465.19 In reply to 1465.18
Don't worry, Michael, I have no problem with this model.
It is only a test to understand what's happen.
I have other models with the same problem with completely different structure but for now I use a little trick:
1 - I look for the part that 'drive' the group
2 - Cycle thru select until it is the only selection (two or three clicks, strange but real)
3 - Click on 'separate' command'. Now the group is ungrouped but all the parts in the group (except the driver) are duplicate.
4 - Delete the duplicate parts.
Unlimited thanks
Gianrico
1465.20 In reply to 1465.19
Hi Gianrico, I'm glad you have a solution!
I you have other sample files that have this same kind of behavior, can you please e-mail me those if possible? (moi@moi3d.com)
That way I will have more samples to test with when I get a chance to work on improving the IGES import.
Show messages: All  1-16  17-20
