Make pipes easier for tubulars/pipes frames professionnals designers
 1-19  20-39  40-59  60-65
1463.60 In reply to 1463.59
Hi Ed,
> I assume using two different shaped profiles is OK?
Yup, it should work fine, just like the example you show there.
If there are a different number of segments between the shapes, it will still work but you will get a lot of kind of funky surface stripes in the in-between part where one shape kind of morphs into the other...
If you have the same number of segments between each profile you will get a cleaner type of 1-to-1 matching between the segments.
1463.61 In reply to 1463.58
Seems you don't have exactly the same result due scaling of the 2 rails :)
I have taken the middle center and internal curves for the 2 rails
and middle center for one rail
and inverse stars for have same order
Remark : curves generator resulting from this Pipes script are different than true offset curves (no showed here)
EDITED: 19 Mar 2008 by PILOU
1463.62 In reply to 1463.61
Hi Pilou - in this case it looks like that is because of the varying radius - I mean different radius at start and end.
A normal offset curve has a constant distance at all spots, that would be more like the same radius at start and end...
1463.63 In reply to 1463.62
Of course :)
EDITED: 20 Mar 2008 by PILOU
Size: 23.5 KB, Downloaded: 219 times, Dimensions: 450x251px
1463.64 In reply to 1463.63
Michael,
Could it be possible to have few informations concerning the pipe created with an information box or inside the creation window ?? : Surface and lenght (of the original rail). Maybe the "informations box" is in project for version 2 ?
Thanks. Pierre.
1463.65 In reply to 1463.64
Hi Pierre, there isn't any way for a script to determine the length of a curve right now, sorry.
Yup, I'm not sure if this one will be in the properties box or as a command in a separate "Analyze" toolbox, but I definitely want to add some analysis commands such as determine length of a curve, volume of a solid, etc... for v2.
Show messages:  1-19  20-39  40-59  60-65
