Make pipes easier for tubulars/pipes frames professionnals designers
 1-16  17-36  37-56  57-65
1463.57 In reply to 1463.56
Frenchy Pilou - Nice example with the "star". I think you have made a solution for a complex shape I have been trying to figure out.
Ed
1463.58 In reply to 1463.57
Nice example Pilou!
Another method to do that is instead of using one star and 2 rails, you can use one rail and 2 stars, like this:
Select those 2 stars (and make sure they are placed away from the bounding box around the rail path), and the run Construct / Sweep, and pick the rail curve to get this:
With this method you don't have to create a pipe first...
But sometimes it can be nice to extract edges for further constructions in different cases, that is a good idea to keep in mind.
1463.59 In reply to 1463.58
There hasn't been this much talk about pipes since the Plumbers Convention in Las Vegas.
I forgot about sweeping using two sizes of profiles. I assume using two different shaped profiles is OK?
Ed
1463.60 In reply to 1463.59
Hi Ed,
Yup, it should work fine, just like the example you show there.
If there are a different number of segments between the shapes, it will still work but you will get a lot of kind of funky surface stripes in the in-between part where one shape kind of morphs into the other...
If you have the same number of segments between each profile you will get a cleaner type of 1-to-1 matching between the segments.
1463.61 In reply to 1463.58
Seems you don't have exactly the same result due scaling of the 2 rails :)
I have taken the middle center and internal curves for the 2 rails
and middle center for one rail
and inverse stars for have same order
Remark : curves generator resulting from this Pipes script are different than true offset curves (no showed here)
EDITED: 19 Mar 2008 by PILOU
1463.62 In reply to 1463.61
Hi Pilou - in this case it looks like that is because of the varying radius - I mean different radius at start and end.
A normal offset curve has a constant distance at all spots, that would be more like the same radius at start and end...
1463.63 In reply to 1463.62
Of course :)
EDITED: 20 Mar 2008 by PILOU
Size: 23.5 KB, Downloaded: 219 times, Dimensions: 450x251px
1463.64 In reply to 1463.63
Michael,
Could it be possible to have few informations concerning the pipe created with an information box or inside the creation window ?? : Surface and lenght (of the original rail). Maybe the "informations box" is in project for version 2 ?
Thanks. Pierre.
1463.65 In reply to 1463.64
Hi Pierre, there isn't any way for a script to determine the length of a curve right now, sorry.
Yup, I'm not sure if this one will be in the properties box or as a command in a separate "Analyze" toolbox, but I definitely want to add some analysis commands such as determine length of a curve, volume of a solid, etc... for v2.
Show messages:  1-16  17-36  37-56  57-65
