| Hi Petr,
 > -both curves are planar
 > -both curves are lying on the same plane
 > -one of them is completely inside the other
 > What do you feel about it, Michael?
 Definitely a good idea!  Maybe something that is used only for auto-place mode?
 It probably is not too difficult to achieve, I already have a mechanism for determining contained planar regions used for Extrude and Planar.
 > edit: And generally, if there was more than two rails selected, MoI
 > would sweep a profile(s) along each rail individually. It would allow
 > "handling a larger number of curves at once" :)
 Yup, I was thinking about this one a bit too. It's slightly odd in that there is an exception for 2 curves being the 2-rail sweep instead... But it seems practical enough, I mean if you only have 2 one-rail sweeps to build, that is not such a big problem to repeat manually.
 Added to the wishlist.
