New Tutorial from productdesignforums.com
 1-8  9-28  29-31
1456.9
Fantastic job, manz!
Would you be so kind as to give us some feedback on your workflow?
Did you follow the tutorial literally, or did you find some shortcuts with MoI?
Were there passages in which you got stuck because MoI doesn't currently perform that kind of operation?
Please, let us know. It could help a lot both beginners and pros.
All the best
Daniele
"The darker the night, the closer the dawn."
(Buddhist Proverb)
1456.10 In reply to 1456.8
>>>I think it looks great! Just maybe an unusual background with the patio type environment...
It was just a very quick render. I dont normally even render most of my models, I just build them then delete them.
>>>Are the engraved lines booleaned in?
I did attempt that on the above model, but had problems. But I found that was due to bad construction early on (I must of been snapping to incorrect end points etc lol) So I rebuilt the main form, then made booleans for the engraving, which did work after making increase in size of the part to boolean out.
EDITED: 3 Aug 2009 by MANZ
1456.11 In reply to 1456.9
Hi Dan,
I am still finding my way around MoI, I have only been using it for about a week (a couple of hours a day), so still trying to find the best direction to follow.
1456.12 In reply to 1456.7
>>>I don't think your shaders/rendering do justice to your modelling!
I did not bother to set up, just used a space/setup I had already.
EDITED: 19 Mar 2008 by MANZ
1456.13 In reply to 1456.12
Manz
Thanks for sending the file. I am looking forward to seeing what I can make it look like for you. But tomorrow pm perhaps. It is 11pm now and I think I need to go to bed.
1456.14 In reply to 1456.13
No problem.
I have been playing more with the etching/booleans.
Will be a very cool object for test :)
1456.16 In reply to 1456.15
Such a great design and the shading potentials are allmost limitless. Hope you enjoy these.
Brian
EDITED: 31 Dec 2008 by BWTR
1456.17 In reply to 1456.16
I see you are using Carrara (HDRI) for rendering.
1456.18 In reply to 1456.17
Yes Manz.
It seems the best thing to use for jewellery type rendering.
1456.19 In reply to 1456.18
I do have Carrara 6 pro (along with other apps), I purchased that some time ago, but have only recently had spare time to start looking at it. I do like its import ability (it even imports the 3dm files directly), and the fact it gives full lists (even with pic) of each object.
I will have to look more at the rendering capability.
Regards,
1456.20 In reply to 1456.19
Manz.
From all I read, Carrara rates very highly as a top notch renderer.
Compared to every other app I own or have tried, I find the system and workings of the Shader Room very easy/natural to use by a long way.
And then you can take your MoI model into the Carrara Vertex Room and do all sorts of things like Displacement Painting!.
Great fun.
1456.21 In reply to 1456.20
I have been looking at Carrara, and do find it very interesting. I certainly need to learn lots more.
I made render of the my ring model (many times) but decided to post this (even though I could possibly get better (eventually))
This is the later version that I rebuilt.
To Michael, yes, for the etching, I used project/sweep/boolean, which worked very well.
Steve
1456.22 In reply to 1456.21
That's a noticeable improvement, much richer and more lustrous feel.
1456.23 In reply to 1456.22
Thank you, I do agree that textures etc within a render can make a big difference.
To all:
But detail within the model is if great value (IMHO) on such a closeup. I mentioned that I made boolean for the etching, but also made chamfer on the various cutouts (maybe not easily seen, but do apply) These where made easily with MoI.
A quick view of what I mean:
1456.24 In reply to 1456.23
Manz
Yes, that render does justice to your modelling.
A lot of learning involved with lighting and rendering and Carrara is one of the bettere ones to easily learn and use.
Some very valuable plugins--at low prices--can really take you into another level (when you are ready).
1456.25 In reply to 1456.23
Wow Manz,
Your model and the last render is great. My son is just starting out at CCS in the craft program for metals so I'm intrigued by all the jewelry on this forum.
Are you using Carrara or other soft at the moment for your render and mats?
Regards,
David
1456.26 In reply to 1456.25
Hi David,
I am using Carrara 6 pro at the moment.
Regards,
- Steve
1456.27 In reply to 1456.26
Very nice, I purchased Carrara 6 pro from DAZ and regretted the decision at first. I was unwilling to let the purchase be for nothing so I started playing with it lately and have been enjoying it as of late. It can render quickly & look pretty good plus the materials are easy to work with.
Your render is definetaly some inspiration to keep at it.
David
1456.28 In reply to 1456.16
Hey Brian, I like that second render with the plasma or ?, Nice.
David
Show messages:  1-8  9-28  29-31
