Few whishes
All  1-9  10-14
1436.10
ok well, this does work for import speedup but then all patches are exploded into separate pieces and global joining fails.
is this import thing can be multithreaded or something ?
1436.11 In reply to 1436.10
Hi Iwan,
If the model is very complex, you may need to process it more in chunks, like select a batch of surfaces and try to join those, then another batch, etc...
It is hard for me to give more specific advice without being able to work with the model over here, if you want to send it to me at moi@moi3d.com I could try to help out some more.
I guess it is theoretically possible, but it is extremely difficult work to take a large complex piece of code like a file importer and totally change it all to be multi-threaded. That's probably not going to be feasible to attempt anytime soon.
One part that I do want to make multithreaded first will be meshing, which could help this some though too, although really a wireframe display mode would probably be the biggest help for processing large models instead.
1436.12 In reply to 1436.11
OK thank you Michael.
I can't give away the model because, even if I was allowed to, it's 1.5 GB :)
1436.13 In reply to 1436.12
Hi Iwan, is the model just one single huge part?
Or is it an assembly made up of many different parts in it?
If it is made up of many different parts and the parts are organized to belong in different IGES "group" entities, then I think it would be possible for me to improve this by only attempting to join surfaces that belong to the same group. That is a lot more efficient than a total global join attempt.
By the way I just realized that I may have misunderstood your question about multithreading - I do want to make it possible to interrupt a big IGES import, which may involve multithreading for that purpose. The part that will be hard that I was talking about was to try and use multithreaading to improve IGES import performance on multi-core processors, that kind of thing is much more difficult.
1436.14 In reply to 1436.12
Hi lwan,
That is a big file,
I would ask the client for breakdown, or for conversion at source.
Or possibly have at look at http://www2.rhino3d.com/resources/display.asp?language=&listing=414
Show messages: All  1-9  10-14
