Cup Handle Problem
All  1  2-4
1424.2 In reply to 1424.1
Hi Brian, your handle is kind of just skimming along the outer edge of your cup body, it isn't sticking all the way through it.
Zooming in on this area:
You can see that there is some space between the handle and the body:
Zoom in to that area and then drag the handle over a little bit so that it is sticking through there a little bit, best is so that it is about half-way through the wall of the body, like this:
After that the boolean should work fine, and then a fillet will work up to about a max of 0.45 radius:
Let me know if you have any more problems with it!
1424.3 In reply to 1424.2
Thanks Michael.
1424.4 In reply to 1424.3
And, after a bit of fun in Carrara6.1Pro!
EDITED: 30 Dec 2008 by BWTR
Show messages: All  1  2-4
