File has no print option?
All  1-5  6-8
1412.6 In reply to 1412.4
Hi Gaston, I tried your script over here and it seemed to work fine for me in version 1.0 .
One thing - please make sure there is no carriage return in the text that you paste in to the shortcut command. If there is a carriage return it can cut it short, and there does appear to be a return in your message text.
Try copy/pasting this one long line:
script:var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; }
If your video card supports it, you may be able to go to a higher resolution than 2560x2560 as well, just edit the 2 numbers in the script.
1412.7 In reply to 1412.6
I changed the resolution to 1280,1024 and it works very well now :o)
Thank you.
Gaston
1412.8 In reply to 1412.7
Great! I hope that will help at least some.
Probably your video card would need an upgrade to one with a larger amount of video memory to go higher.
Show messages: All  1-5  6-8
