File has no print option?
All  1-3  4-8
1412.4 In reply to 1412.3
Thank you Phil, PrintScreen works fine I have to try to see if it is possible to preserve scaling; get a 1:1 relationship.
MIchael, this sounds very interesting except the link http://moi3d.com/beta/Sep4_patch4.zip is broken :(
And I would be hesitant to replace moi_lib.dll 2008-01-18 with an older one.
I have tried associating a Shortcut key P to the suggested script
script:var v = moi.ui.getActiveViewport();
if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; }
but it does not seem to work with version 1.0 anyway. Any other way around?
Thank you,
Gaston
1412.5 In reply to 1412.4
Hi Gaston, you shouldn't need that link anyway, this functionality is built into every version newer than last September's beta release. It should work in version 1.0, I'll take a look and see what might be going wrong.
Also, what video card do you have? Some video cards may not allow creating the image larger than the screen...
1412.6 In reply to 1412.4
Hi Gaston, I tried your script over here and it seemed to work fine for me in version 1.0 .
One thing - please make sure there is no carriage return in the text that you paste in to the shortcut command. If there is a carriage return it can cut it short, and there does appear to be a return in your message text.
Try copy/pasting this one long line:
script:var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; }
If your video card supports it, you may be able to go to a higher resolution than 2560x2560 as well, just edit the 2 numbers in the script.
1412.7 In reply to 1412.6
I changed the resolution to 1280,1024 and it works very well now :o)
Thank you.
Gaston
1412.8 In reply to 1412.7
Great! I hope that will help at least some.
Probably your video card would need an upgrade to one with a larger amount of video memory to go higher.
Show messages: All  1-3  4-8
