Hi lyes, that is a great looking result!
> note: the projected curves they update on surface changes , only if the
> project curve is located in one place in one pice,
Yeah, this is a general limitation of the history mechanism right now, it will get confused in commands where the command generates multiple output objects instead of a single output object. I definitely plan on improving this in the future.
> here if michael can do : to set distance off curve projection will help!!!,
Do you mean like a kind of "depth limit" to the projection?
> or even better match surface to selected curves , looks like same as network surface tool !!!
Could you please describe this one a little bit more?
