Mercedes_SLK
All  1  2-6
Added to the special thread gallery :)
EDITED: 25 Feb 2008 by PILOU
1408.3 In reply to 1408.1
Hi lyes, that is a great looking result!
> note: the projected curves they update on surface changes , only if the
> project curve is located in one place in one pice,
Yeah, this is a general limitation of the history mechanism right now, it will get confused in commands where the command generates multiple output objects instead of a single output object. I definitely plan on improving this in the future.
> here if michael can do : to set distance off curve projection will help!!!,
Do you mean like a kind of "depth limit" to the projection?
> or even better match surface to selected curves , looks like same as network surface tool !!!
Could you please describe this one a little bit more?
1408.4 In reply to 1408.3
for distance off curve projection yes depth limit.
match surface to selected curves here is picture !!!!
1408.5 In reply to 1408.4
wow!
can't wait to see the render!
vince
1408.6 In reply to 1408.4
Hi lyes, thanks for the clarification, I've added these to the wishlist (http://moi3d.com/wiki/Wishlist).
Show messages: All  1  2-6
