Mercedes_SLK
1408.1
her is my 1st car mercedes 2 doors i start it with half blob made with network curves created on blue print with a minimum
control points no hood ,after i projected arch weel cut as line from top off car and puled pushed control pts to match circle cut in side view,
same as front and back lights projected as curves from front and back view ,
note: the projected curves they update on surface changes , only if the project curve is located in one place in one pice,
here if michael can do : to set distance off curve projection will help!!!,
or even better match surface to selected curves , looks like same as network surface tool !!!
EDITED: 25 Feb 2008 by BLYESS
Size: 95.1 KB, Downloaded: 125 times, Dimensions: 1342x766px
Size: 101.7 KB, Downloaded: 109 times, Dimensions: 1258x923px
Added to the special thread gallery :)
EDITED: 25 Feb 2008 by PILOU
1408.3 In reply to 1408.1
Hi lyes, that is a great looking result!
Yeah, this is a general limitation of the history mechanism right now, it will get confused in commands where the command generates multiple output objects instead of a single output object. I definitely plan on improving this in the future.
Do you mean like a kind of "depth limit" to the projection?
Could you please describe this one a little bit more?
1408.4 In reply to 1408.3
for distance off curve projection yes depth limit.
match surface to selected curves here is picture !!!!
1408.5 In reply to 1408.4
wow!
can't wait to see the render!
vince
1408.6 In reply to 1408.4
Hi lyes, thanks for the clarification, I've added these to the wishlist (http://moi3d.com/wiki/Wishlist).
