I'm a now a proud MoI owner!
1399.1
So I guess it's time for my first daft question. I'm going through the lamp tut (which I'm enjoying a lot - thanks to it's maker), and - hey! - I ran into a little problem.
I cannot put a fillet around the lamp button. As this is my first MoI model, I'm probably overlooking something obvious - but of course I have no idea what. (It's not the radius, though. At least, I don't think so.)
Any help will be greatly appreciated.
1399.2 In reply to 1399.1
Hi stinkie, thank you very much for your order!
The switch has a pretty narrow area on it here:
There really isn't very much space in that area to fit fillets - here I have done a fillet of radius 0.03:
Zooming on that narrow region, you can see that there isn't room for much more of a larger radius than that:
Much larger than that and that side piece will be totally eaten away - that will cause the fillet to fail to calculate.
It is often times surprising how much space a fillet will take up, if you are not getting a result try something really pretty small like 0.01 or 0.005 and see if that works, then gradually increase the size.
Hope this helps!
1399.3
Hi !
Fillet radius 0.05 did it !
Its probably the radius !
Peter
1399.4
Thank you, Michael, that does indeed help. Much obliged.
I've greatly enjoyed using MoI so far. Very intuive app - the UI really is a gem. I just know MoI and myself are going to be really good friends.
Please don't thank me for buying MoI. Thank my girlfriend - she's the one with the Visa card. ;)
And thank you too, Rayman!
