Extrusion problem
1397.1
Can anyone tell me what I'm doing wrong?
I checked out the extruding text on a curved surface post and was able to do that without a problem.
However, I'm finding I'm having a problem doing a simple extraction along these lines:
If I create a solid cylinder and trim a circle out of its side and try to extrude that circle (similar to the way you do text) I find that the etrusion only slides along the surface parallel to the cylinder wall. I cannot get it to extrude perpendicular to the wall. Why does it work for the text extrusion but not in this case?
Brian
1397.2 In reply to 1397.1
can you post a little image? (With attachments button)
or a file 3dm
1397.3 In reply to 1397.2
Hi Brian
Is this what you mean?
I just did the same as with text on a round object.
Hope it helps
Size: 65.2 KB, Downloaded: 49 times, Dimensions: 1203x892px
1397.4 In reply to 1397.3
Maybe i'm wrong but maybe you could set the direction when extruding? (it's an option in the info panel)
As a final touch, God created the Dutch
1397.5 In reply to 1397.1
Hi Brian, by default a non-planar curve will extrude in the z-axis direction.
For your text extrusion, probably that was the desired direction, but for your cylinder I would guess that your cylinder is vertical so you would rather extrude in the y-axis direction instead of z-axis.
To do this, push the "Set dir" button (as Edwin mentioned) that shows up when you are inside the Extrude command. This will allow you to pick 2 points, and the line between those 2 points will become the extrusion direction. So pick 2 points along the y axis in this case and your extrusion will go in the y-axis direction instead of the default z-axis direction.
1397.6
Thanks guys.
Brian
