Wrinkles in 3ds exports?
 1-6  7-21
1392.7 In reply to 1392.6
Michael there are some odd things about various files save types into or via other apps that I have not been able to fathom out. On any one MoI file, exporting as Iges may be best , on another MoI file export 3ds, on another Lwo, on another 3dm.
EDITED: 30 Dec 2008 by BWTR
1392.8 In reply to 1392.7
Hi Brian, well 4 of the formats you list there will rely on your target application to convert the NURBS data into a polygon mesh.
This includes your:
#1 .3dm from MoI -> import .3dm into Carrara (meshed on import into Carrara)
#2 .3dm from MoI -> import .3dm into Amapi (is this correct?) -> export .3dm from Amapi -> import .3dm into Carrara (meshed on import into Carrara)
#3 .3dm from MoI -> import .3dm into Amapi -> export .obj from Amapi -> import .3dm into Carrara (meshed on export from Amapi)
#4 .igs form MoI -> import .igs into Carrara (meshed on import into Carrara).
If you're seeing strange polygonization in any of these routes, you should contact the authors of the program that is performing the polygonization to see what might be going wrong. In all of these cases it is not MoI that is generating the polygon information.
The polygon information is what actually gets finally rendered, in all cases.
The route that I have the most control over is when you export a mesh format from MoI.
LWO is generally not the best except for going into Modo, LightWave, or Blender.
Programs other than Modo or the Blender LWO importer will not read vertex normal smoothing information from the LWO file, and instead will calculate smoothing by averaging adjacent faces. This can lead to some shading errors.
If you must use LWO export, it is probably a good idea to switch to Output: Quads & Triangles. If you export n-gons then you are also relying on your target application's ability to convert the n-gon into triangles, and this is another area which can be messed up fairly easily.
Generally the best bet is to use OBJ format, since that can translate vertex normal information over, which really helps to generate a smooth object.
Some programs deal with unwelded information better than welded information in OBJ files, so you might try expanding the meshing options dialog and uncheck "Weld vertices along edges".
OBJ file also have the option of using n-gons or quads & triangles. Again using quads & triangles here can help avoid n-gon triangulation problems in your target application.
So an overview: try OBJ export, switching 2 options - change Output : n-gons into Output: Quads & Triangles, and expand the dialog by the arrow in the lower left corner and un-check "weld vertices along edges".
Does that type of OBJ export work more reliably for you?
1392.9 In reply to 1392.8
Thanks Michael.
Following an earlier thread, I had reported two file type problems to Carrara (Daz).
I am surprised at the variations of import acceptability into Amapi and Carrara of identical files and, what you say I guess ties in somewhat.
This crazyness is way beyond a joke. Will that universal 3D file type Collada ever be properly organised?
I prefer to save in file types which keeps the various "parts" separated--so much easier for shading. To have to go through that slow creating of "shading domains" with obj files is a real drag.
Should I think of saving all the individual parts as individual obj file? Aaaahhhh!---It looks like it.
Carrara has allways been considered as not accepting obj n-gon files----a real nono!
I just did an exercise with that spray can and Carrara 6.03 accepted the (welllllll----that file!!!) n-gon version with relish?
AAaaaahhhhhh!
1392.10 In reply to 1392.9
Hi Brian, give this utility a try:
http://moi3d.com/wiki/Resources#SeparateOBJ_editor
If you run your OBJ file through that SeparateOBJ.exe program, it will re-label some parts inside of it, and that may get Carrara to recognize different pieces without messing around with shading domains.
I'm not sure if it will work but it is worth a try...
1392.11 In reply to 1392.10
BRILLIANT!
Thanks Michael!
1392.12 In reply to 1392.11
Hi Brian, does that handle what you were doing with shading domain stuff ok then?
1392.13 In reply to 1392.12
Michael--with GREAT caution!---maybe thats the solution!
IF its the answer, maybe that should be the DEFAULT Obj file save from MoI?????
? a Perfect all round solution?
1392.14 In reply to 1392.13
Hi Brian, yup I think that will become the default save method for v2.
I'm glad that seems to help!
1392.15 In reply to 1392.14
And you are going to prioritise those "essentials" in that V2 version Beta in a couple of days?
When you get to my age you will ReALLY appreciate the fun joke!
"Once upon a time it was easy to do-------do!~ dodooo!"
All aside, your obj solution is about as good a "Collada" solution--geeesee it's so simple it makes the brain explode!
1392.16 In reply to 1392.15
To tell you the truth, I'm not really quite sure yet how things will schedule for V2.
This particular thing involves material definitions on objects, so it may fit more naturally (without having to re-do stuff) after there is a way to assign properties to objects.
1392.17 In reply to 1392.16
Michael.
Prioritising is very very easy, you start off with the threads by a bloke BWTR and then alphabetically through the rest!
See how easy it was for me to take that decission weight off your shoulders>
Brian
1392.18 In reply to 1392.17
Michael, getting back to that great learning post of yours (1392.8)
I would, never ever have considered unchecking the weld vertices as you suggested fo the obj save. Just the opposite!
The world is strange.
Anyway, there is still so much I don't understand. Would you care to make any comment on the settings for your MoI obj file save when importing into Carrara as per the attached please.
1392.19 In reply to 1392.18
Hi Brian, well one thing that is difficult is that each program may have its own unique terminology.
Like for example in your dialog there I don't really know what the difference is in Carrara between a "Facet Mesh" and a "Vertex Primitive".
Sometimes the auto position and auto scaling can create alignment problems when you want to import pieces from several different files. Basically if each piece gets scaled to the same uniform size, relative sizes between each piece will get lost. So sometimes you might want to un-check "AutoPosition" and check "Disable Auto-scaling". But this is not likely to be an issue when you are importing just a single file to work on.
The "Map OBJ Y to Carrara Z axis" should only be used if your objects seem to be coming in rotated 90 degrees from the original. If they are then flip this checkbox.
Assume UV Coordinates are Between 0 and 1 - that should be checked, MoI does export UV coordinates between 0 and 1.
I would say the "Create one Object per Group" you want to have on, that will help get your pieces separated so you can assign different materials more easily.
1392.20 In reply to 1392.19
Thanks Michael.
Thats all been a great learning curve for me. I think I have a much clearer understanding of a lot of app file interrelationship problems that have worried me in the past.
Strangely, the Map axis option does have to be checked for MoI .obj files.
The Facet Meshes option is very odd. You then have to convert the items within Carrara if you want to work on them in the Vertex Room!(Which can be slow) I can not see a benefit.
So much I learned. MoI Obj saves is great. Thanks again
Brian
1392.21 In reply to 1392.20
I guess that must be some remnant from an older version of the software...
You're welcome! I'm glad that you've got a good method for translation now.
Show messages:  1-6  7-21
