Tut Video by Steph3D
All  1-5  6-12
139.6
Thanks a lot.
But the link is broken
EDITED: 28 Sep 2006 by SHAK
139.7 In reply to 139.6
Ps in one or two days maybe Steph will make an Update movement of his site
so the video maybe not visible during this transfert :)
It was writed on the first post :)
EDITED: 28 Sep 2006 by PILOU
139.8
Hmmm, I can't watch it as I'm sporting quicktime7 and that codec won't install under 7. Why does steph use a non-standard codec pilou?
139.9 In reply to 139.8
Curious that work not for you?
the only prob was when the horst provider was clashed
Now is normal!
The codec don't work for you? Seems you are the only one!
He uses this codec because it a very good compress for the quality
139.10 In reply to 139.1
> Maybe you you must have this codec http://www.3ivx.com/download/windows.html
From their site...
Note: The Audio Encoder and Audio Decoder are restricted to 50 encodes or a maximum usage of 30 days.
QuickTime 7: Due to changes in QuickTime, the current 3ivx Installer does not work correctly with QuickTime 7 for Windows. We expect to correct this problem shortly.
When I go to the site with the video I just end up staring at a big blue Q. I feel like I'm working at Qwest again and it gives me the the shivers.
139.11 In reply to 139.10
I don't know what to say you :(
It's works fine for me on XP I try again now, no special problem :)
I just wait some second at the start for loading...( a big blue Q too) ....there is no sound so no restriction ;)
EDITED: 30 Oct 2006 by PILOU
139.12 In reply to 139.11
Ok. I will try it again then. Maybe I just need to be more patient.
Show messages: All  1-5  6-12
