Sweep tool problem
All  1-8  9-13
1389.9
Agreed, having a dependencies on positioning kills a creative session - especially when you don't know (or forget) that a tool has a dependency for this or that...
-Will
1389.10 In reply to 1389.9
Maybe when you choose "flat", I can default to the world z axis direction, but show a button underneath it that says "Set flat dir", and if you push it let you pick 2 points to define the direction.
1389.11 In reply to 1389.10
Why not automatic get helix both end points?
1389.12 In reply to 1389.11
Hi Johny - that would be difficult because the default isn't "flat" mode, it is the freeform twist mode which does not need any direction information.
So that would feel a little odd if I forced you to pick 2 points every time you did sweep, but then did not use that information by default.
1389.13 In reply to 1389.12
Ah, I think you're right Michael ;)
Sorry, I forgot that 3dm file format not save start and end point of created helix information.
And I agree with a button option for select start and end point of direction if we select Flat mode.
Show messages: All  1-8  9-13
