Sweep tool problem
1389.1
Sweeped a triangle profile on helix rail give odd result as shown on bellow image.
Can anyone help me with this problem? Or maybe explain why this happened?
I also attached 3dm file for test.
Size: 64.3 KB, Downloaded: 102 times, Dimensions: 821x553px
1389.2 In reply to 1389.1
You have done a freeform twist not a flat twist, look under sweep options , there is a choice,
Tim.
1389.3 In reply to 1389.2
Thanks for the answer Tim :)
But Flat option also give odd result as below image ???
Size: 99.5 KB, Downloaded: 99 times, Dimensions: 883x693px
1389.4 In reply to 1389.3
Curious that works fine at home ?
Put the triangle perpendicular and out of a "bounding box" of the helix and make the sweep
EDITED: 16 Feb 2008 by PILOU
1389.5 In reply to 1389.3
Hi Johny - for the flat option your helix should be oriented along the world Z axis.
So if you go the the right-side view and rotate it 90 degrees, and then repeat it with the flat option it should work how you want.
1389.6 In reply to 1389.5
Thanks Michael, its works well on z axis :)
PS: Wish on v2, its works well on any direction ;)
1389.7 In reply to 1389.6
added to the whish list :)
1389.8 In reply to 1389.7
Thanks PILOU! :)
1389.9
Agreed, having a dependencies on positioning kills a creative session - especially when you don't know (or forget) that a tool has a dependency for this or that...
-Will
1389.10 In reply to 1389.9
Maybe when you choose "flat", I can default to the world z axis direction, but show a button underneath it that says "Set flat dir", and if you push it let you pick 2 points to define the direction.
1389.11 In reply to 1389.10
Why not automatic get helix both end points?
1389.12 In reply to 1389.11
Hi Johny - that would be difficult because the default isn't "flat" mode, it is the freeform twist mode which does not need any direction information.
So that would feel a little odd if I forced you to pick 2 points every time you did sweep, but then did not use that information by default.
1389.13 In reply to 1389.12
Ah, I think you're right Michael ;)
Sorry, I forgot that 3dm file format not save start and end point of created helix information.
And I agree with a button option for select start and end point of direction if we select Flat mode.
