Help in making a heart shaped bowl
All  1-6  7-18
1382.7 In reply to 1382.6
A completely different file with the same problem?
EDITED: 30 Dec 2008 by BWTR
1382.8 In reply to 1382.7
Hi Brian, yup I used the file you posted and it worked fine over here.
Also your second file works fine over here as well.
I think the problem you are running into is that you are selecting the original curve objects that you used to extrude, instead of selecting the edges of the solid.
Since those curve objects are in the exact same location as the edges of the solid, it is easy for them to get selected when you click in that area.
So before you do your fillet, select those curves (and in your new file you actually have an extra planar surface object down there as well) and hide or delete them so that when you click to select the pieces to fillet you will be targeting pieces of your solid and not those original curve pieces.
Another way to make this clearer - click and drag on the solid to move it a little bit off to the side, and you will then see these other objects that are getting in your way.
1382.9 In reply to 1382.8
Michael, OK I got things to work with that end comment.
BUT--who, of normal thinking, would know that VERY ODD proceedure needs to be adopted? (Have I missed something in the "Important Instructions"?)
Sorry, but the whole exercise with fillet seems to have ----gnash of teeth---"difficulties"!
Brian
1382.10 In reply to 1382.9
Knowing that before may have saved me many hours of frustration previously on a lot (most?) of my attempts to do things---or, am I the only dummy?
1382.11 In reply to 1382.9
I think in the tutorials I mention hiding or deleting your original curves so that they don't get in the way later on.
Some other people have definitely gotten confused by this same thing. But it isn't a very easy problem for me to solve.
I mean that curve is there because that's where you drew it to begin with... It didn't pop into existence automatically or anything like that.
The only way I can think of to solve this problem would be to try and remove that curve automatically when you perform the extrusion.
However, that is also prone to weird surprises, like if you want to move your object off to the side and edit the curve you drew to make a new extrusion, it wouldn't be there. And in this case it would be some automatic process kicking in and changing the model from what you drew... So that does not seem like a great option to me either.
1382.12 In reply to 1382.10
Another option is that you can select a face for filleting instead of edges.
That can be quicker for things like you are showing since it is just one thing to select instead of many. It will fillet all the edges that belong to that face.
1382.13 In reply to 1382.12
But sellecting the face gives a fillet on all edges!
The problem is that the solution is "odd" to say the least--but, if my memory retains the message, I may not have the problems again?
The thing is, how does the message get ingrained into newcomers thinking/working practices?
Sorry for carrying on, but there are just a very few "odd" working methods in the current version of MoI that either need an SR or very clear working proceedure instructions.
Having coming from a learning of say Carrara and Hexagon (Amapi) maybe the 3D thinking of the likes of me may be different than those who come from a Rhino say background?
Hey!--but MoI is still the best thing sice sliced bread!
1382.14 In reply to 1382.10
I guess a lot of it comes down to how you've learned to do your "workflow"?
Very early on I'd gotten into the habit of hiding my original curves straight after the Surface had been formed.
I tend not to delete them just in case I need to rebuild or use them to modify the model a bit later on.
This of course means that when any Fillets need doing, the only thing I'm able to select is the Surface.
Hope this helps, Colin
1382.15 In reply to 1382.13
Well, only if you select all the faces...
Like if you want to fillet edges just along the top of a shape like this:
Then you can select the top face like this:
Which will produce fillets just along the top edges like this:
Note that there is not a fillet on all edges, just on edges that belong to that top face.
The nice thing is I only had to select one face to fillet all those edges, instead of selecting many edges.
It certainly helps when you describe the problems you are running into, that may give me ideas on how to improve things in the future.
But not everything has a very clear cut solution to it, a change to solve one particular problem may cause new problems in other areas. In this case everything is functioning as it is designed to, so a SR is not the answer.
That's really what the forum is for - it seems like this is all cleared up now with this forum discussion?
But yeah for v2 at least I can add some notes about this in the documentation for Fillet.
If you were running into a lot previously and wasting a lot of time, I guess I'm kind of confused why you didn't post about it earlier?
1382.16 In reply to 1382.15
Colin.
You grasped a concept that my simple brain missed--can I blame it on age?
Michael.
Michael, as your images show, selecting a plane gives fillets on all edges--which was not as I wanted!
Why not complain/comment before?---when do I know the fault is not mine?
I am reminded of the wow tutes by Thomas about Hexagon, which as far as I can see no-one has yet emulated. (Most "crash"!) As Thomas said, he had a team designing the programme to his ideas!
We all dont have the same thought train or app backgrounds, so some will , naturaly, be slow like me.
However, I make a point (?) that some of the basic MoI concepts may be "un-natural" to some and may need highlighting if they can not be changed in V2.
How do you highlight those "different" things in the, very first, introduction to the app? Now theres a puzzle!
(Hidden in a tute is not sufficient maybe?)
1382.17 In reply to 1382.16
> fault is not mine?
Well, it certainly is true that it is generally helpful for you trying to work things out for yourself before bringing it up.
But at the same time if you keep running into it or it is taking a significant amount of time, please do bring it up.
It's important for me to know what things people find confusing.
And for instance in this case it didn't take long to clear it up...
I certainly agree with your point!
I don't generally expect for 1.0 to be perfectly natural in all operations to all people from all different backgrounds. That's pretty much impossible...
But I can make improvements as time goes on though!
Yes, that is the difficult thing to figure out. The other major complicating factor is that the things that are different change depending on your particular background.
I think that tutorials are probably the most straightforward solution though - for example if I had a tutorial that did some extrusions and filleting that might have been able to cover this a bit more since extrusions tend to have the curves overlapping the generated objects more so than the commands I happened to use in the other tutorials.
In the future I would like to do some more tutorials and I can try to cover this with them.
1382.18 In reply to 1382.17
Thanks Michael.
Show messages: All  1-6  7-18
