Help in making a heart shaped bowl
All  1-16  17-18
1382.17 In reply to 1382.16
> Why not complain/comment before?---when do I know the
> fault is not mine?
Well, it certainly is true that it is generally helpful for you trying to work things out for yourself before bringing it up.
But at the same time if you keep running into it or it is taking a significant amount of time, please do bring it up.
It's important for me to know what things people find confusing.
And for instance in this case it didn't take long to clear it up...
> However, I make a point (?) that some of the basic MoI
> concepts may be "un-natural" to some and may need highlighting
> if they can not be changed in V2.
I certainly agree with your point!
I don't generally expect for 1.0 to be perfectly natural in all operations to all people from all different backgrounds. That's pretty much impossible...
But I can make improvements as time goes on though!
> How do you highlight those "different" things in the, very first,
> introduction to the app? Now theres a puzzle!
Yes, that is the difficult thing to figure out. The other major complicating factor is that the things that are different change depending on your particular background.
> (Hidden in a tute is not sufficient maybe?)
I think that tutorials are probably the most straightforward solution though - for example if I had a tutorial that did some extrusions and filleting that might have been able to cover this a bit more since extrusions tend to have the curves overlapping the generated objects more so than the commands I happened to use in the other tutorials.
In the future I would like to do some more tutorials and I can try to cover this with them.
1382.18 In reply to 1382.17
Thanks Michael.
Show messages: All  1-16  17-18
