Rendering glitch from 3DM file
All  1-16  17-19
1361.17 In reply to 1361.16
That was a good starting point - actually by using the Planar command you create a large plane that is trimmed by those curves. It is quite similar to the kind of build-large-sheet-then-trim-back method that I showed above.
1361.18
Wasn't there a script posted a while back that enabled you to highlight "open" edges or something like that?
It made a good tool for checking your surfaces to see if they were closed as you expected - actually I think it was perhaps as simple as turning on points? (Or perhaps selecting certain points?) Don't remember now...
-Will
1361.19 In reply to 1361.18
http://kyticka.webzdarma.cz/3d/moi/
there is Select all curve closed here
Show messages: All  1-16  17-19
