Change color and thickness of lines?
All  1-4  5-6
1358.5 In reply to 1358.4
Wow you are fast - thank you !
1358.6 In reply to 1358.4
Hi Tom, also I should mention that you'd use the LineWidth= setting in moi.ini if you wanted to increase the size of the lines.
If you want to make the lines lighter instead of thicker, there is a different setting that can help with that:
[View]
UseThinAntiAliasing=n
Switch it to UseThinAntiAliasing=y and the blended area around the outside of lines will be lessened, making for a lighter looking line display.
Show messages: All  1-4  5-6
