Change color and thickness of lines?
All  1-3  4-6
1358.4 In reply to 1358.3
Hi Tom,
> Is it also possible to change the thickness of the selected yellow lines (curves / edges) ?
> I searched through the CSS file but not sure where ;-)
Selected lines are automatically set to be 2 pixels wider than regular lines. So you can't set it directly but if you adjust the regular display line width it will follow along with that.
The regular line width can be set in moi.ini (go to Options > General > "Edit .ini file" button, then under the [View] section you'll find:
[View]
LineWidth=1.0
1358.5 In reply to 1358.4
Wow you are fast - thank you !
1358.6 In reply to 1358.4
Hi Tom, also I should mention that you'd use the LineWidth= setting in moi.ini if you wanted to increase the size of the lines.
If you want to make the lines lighter instead of thicker, there is a different setting that can help with that:
[View]
UseThinAntiAliasing=n
Switch it to UseThinAntiAliasing=y and the blended area around the outside of lines will be lessened, making for a lighter looking line display.
Show messages: All  1-3  4-6
