Creating a Crusader Helmet
All  1-6  7-13
1338.7 In reply to 1338.5
Does the edge direction of the polygons have any bearing on the end smoothness? If your file had been saved to tris I think it would have looked just as 'poly-twisted" but also not have any effect on end results. I regularly see this sort of thing but have never taken any notice of it as a potential problem?
I look forward to a properly informed reply.
1338.8 In reply to 1338.7
Hi Brian, it doesn't particularly have any effect on regular rendering.
But if you wanted to use polygon modeling tools to do some further editing of the model in the polygon environment, then of course it is nice to have the polygons as well organized and structured as possible.
There are also some other cases where it can make a difference, like you may want to do some special rendering effects where you actually display the wireframe to get a kind of technical design look.
1338.9 In reply to 1338.8
Thanks Michael.
It follows, for how I generally work, that I dont really need to add this extra "worry detail" to my methods.
1338.10 In reply to 1338.9
Obviosly I am trying this Helm idea as well.
When I try to boolean the holes in the helm I also get a set of holes at the back--seems very odd?
EDITED: 22 Nov 2008 by BWTR
1338.11 In reply to 1338.10
I guess I worked it out. You have to start with an extrudedobject before starting the array!
Anyway, quite happy with the quick exercise as per the jpeg. More learning into the basket.
1338.12 In reply to 1338.11
And some rendering fun with Carrara5Pro.
EDITED: 31 Dec 2008 by BWTR
1338.13 In reply to 1338.10
It looks like you figured it out already, but just in case - what seems to have happened here is you arrayed not only your cylinder, but the original circle curve that created the cylinder as well.
Then probably those circle curves got selected as cutting objects in addition to the cylinders.
When you use a curve as a cutting object in a boolean operation, it will slice all the way through the object, it won't only cut just the front side of it.
Nice flag at the top, you are really getting the hang of things!
Show messages: All  1-6  7-13
