End Closure Problem
All  1-4  5-9
1335.5 In reply to 1335.4
Thanks Michael. I found them all. eventually. Very, very close up to find some of those wierd ones.
I hope I will remember to do more ,in depth!, analysis.
1335.6 In reply to 1335.4
Actually the one arc on the lower inside is ok - it is an arc in the upper-left corner that is not quite tangent to the line it is next to, it comes within 1.5 degrees of being tangent.
Things that are very close to being tangent but just a small amount off tends to be problematic for the filleter, it will see it as a sharp corner and try to construct a fillet corner piece there which will be microscopic and tend to gunk things up.
So another tune up is to get those arcs and lines to be trued up instead of slightly off.
1335.7 In reply to 1335.6
Hi Brian, I've attached a tuned up version of the profile curve here - I fixed some of the tangent alignment problems by turning on control points and using Transform/Align to make sure that points between segments that were only very close to being tangent were trued up to be exactly tangent.
This was basically selecting sets of points that looked like they should be lined up horizontally or vertically but were just slightly off - then align can make them all be straightened out.
You can now extrude this profile (attached as RingTry_tuned.zip), then cut it and the result can be filleted properly:
You can go up to about a 0.4 radius fillet before there isn't any room left at the very bottom part of the ring.
It would be nice if you didn't have to worry about any of this, but the filleter is sensitive to any kind of irregularities at all.
Maybe I can tune this up a bit inside Join or something, to true up tangents between joined pieces if they are within 3 or 4 degrees of each other, that might help. I have made a note to myself to investigate doing some automatic cleanup like this in the future.
1335.8 In reply to 1335.7
You are very good Michael. I had solved it all--but a very slow process. No doubt a refing of the workings as you suggest sound good.
Hope you like my end result efforts. (Carrara6Pro)
EDITED: 30 Dec 2008 by BWTR
1335.9 In reply to 1335.8
And another ring just for fun.
EDITED: 27 Sep 2008 by BWTR
Show messages: All  1-4  5-9
