Kerkythea
All  1-6  7-12
1309.7 In reply to 1309.6
In all the cases Kerkythea accept all options! Ngones, Quads + triangles, triangles, and transform all in triangles!
I don't know yet for the next release Kerkythea Echo january 30 :)
1309.8 In reply to 1309.6
I generally triangulate using MoI for everything I want to import into Kerkythea. That applied to anything I did from truespace too. If I don't, I can sometimes find additional surfaces in my imported obj. So, when I said K obj import was rock solid, I suppose I should have said it has been rock solid for me providing I triangulate in my modeler first. It could of course be bad modeling on my part. I've attached some example images.
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
1309.9 In reply to 1309.8
Hi Mark,
Doesn't look like it to me - it looks like a problem with Kerkythea's triangulation mechanism.
But yes, exporting triangulated from MoI (or probably Quads & Triangles should be fine) should avoid this problem.
It's pretty difficult to make a triangulator that handles all kinds of complex concave n-gons properly, if the algorithm gets confused, it is easy for it to try and connect up a triangle between 2 points where it shouldn't because it will cause a "leak" outside of the boundary.
1309.10 In reply to 1309.9
just a question
when you enable "Weld Vertice along edges" in Moi : there is no parameter for the strength of this process?
because seems export obj to Zbrush : when you subdivise in Zb : objects seems unweld after a first subdivision!
I have retaken the wire model by Shadows44
http://moi3d.com/forum/index.php?webtag=MOI_FRANCAIS&msg=103.3
and made some sweep between curves for test :)
EDITED: 31 Jan 2008 by MICHAEL GIBSON
1309.11 In reply to 1309.10
Hi Pilou - I seem to remember that ZBrush does some kind of automatic unwelding when it imports .obj files in some circumstances - I think it is when the welded points have different vertex normals for the 2 faces that share the point.
Since ZBrush is doing this unwelding on import, you'll need to do the weld operation inside of ZBrush to fix it up - I don't know what is called, look for something like "weld", or "merge vertices", or "glue vertices"...
1309.12 In reply to 1309.11
I will examine that :)
Show messages: All  1-6  7-12
