Extruded text on curved surface
All  1-8  9-17
1303.9 In reply to 1303.8
clegg/michael. I dont seem to grasp all in your last 4 related posts--could you help, maybe graphically, explain please?
(Probably me having another "brian" day!)
1303.10 In reply to 1303.9
Hi Brian, see if this helps:
The most basic way of using extrude (which I think you are already familiar with), is to select a curve like this:
Which then after extrusion will result in an object like this:
However, if the curve is not a flat planar curve, it won't become automatically capped at the top and bottom when doing the extrude.
There is another way that you can use extrude instead of using a curve as the initial object. It is also supported to use a surface as the initial object, like this:
After extruding, with that surface selected as the input, this object will be created:
That type of extrusion will always have a cap even if the starting surface was not planar - this is because MoI is able to make a copy of the starting surface to the other end to construct the cap in this case.
Does that make sense?
1303.11 In reply to 1303.10
Thanks Michael--I still can not get the working connection for doing the type though?
I tried doing a sweep of a horizontal/vertical curve to create a cutting surface as in attachments. I think this is not what is meant though either.
EDITED: 30 Dec 2008 by BWTR
1303.12 In reply to 1303.11
Hi Brian, it would go something like this:
Start with text that are curve objects (not solids), flat on a plane:
Now a curved surface over top of them:
Then select the surface and run Edit/Trim - pick the curves as the cutting objects and at the "select pieces to remove" prompt, just push "Done" or right-click to keep all the pieces. This will cause the surface to be sliced up into multiple different surfaces.
Select the inside surface pieces:
Then those can be extruded just like I was showing in that previous post:
seems there was yet a thread about that some times ago :)
1303.14 In reply to 1303.13
Thanks Michael---I was def not thinking like that!
Added to my Help file folder.
1303.15 In reply to 1303.14
I hope this shows my thick scull is learning!
EDITED: 27 Sep 2008 by BWTR
1303.16 In reply to 1303.15
And!
Fine kangaroo!
Show messages: All  1-8  9-17
