Extruded text on curved surface
All  1-10  11-17
1303.11 In reply to 1303.10
Thanks Michael--I still can not get the working connection for doing the type though?
I tried doing a sweep of a horizontal/vertical curve to create a cutting surface as in attachments. I think this is not what is meant though either.
EDITED: 31 Dec 2008 by BWTR
1303.12 In reply to 1303.11
Hi Brian, it would go something like this:
Start with text that are curve objects (not solids), flat on a plane:
Now a curved surface over top of them:
Then select the surface and run Edit/Trim - pick the curves as the cutting objects and at the "select pieces to remove" prompt, just push "Done" or right-click to keep all the pieces. This will cause the surface to be sliced up into multiple different surfaces.
Select the inside surface pieces:
Then those can be extruded just like I was showing in that previous post:
seems there was yet a thread about that some times ago :)
1303.14 In reply to 1303.13
Thanks Michael---I was def not thinking like that!
Added to my Help file folder.
1303.15 In reply to 1303.14
I hope this shows my thick scull is learning!
EDITED: 27 Sep 2008 by BWTR
1303.16 In reply to 1303.15
And!
Fine kangaroo!
Show messages: All  1-10  11-17
