TABLET SET UP
1302.1
HI ALL I JUST BOUGHT MOI 1 AND WANT TO KNOW A GOOD SET UP FOR A TABLET PC TO RUN IT ANY SUGGESTIONS ARE WELCOME BEACAUSE IM SOMEWHAT COMPUTER ILLARATE
1302.2 In reply to 1302.1
Hi Mike, thanks very much for your order!
I think that pretty much any brand new TabletPC will be able to run MoI fine.
Some of the ones that are many years older may not have very good 3D video hardware on them, but this should not be a problem with a newer one.
If you'd like, after you pick one out post the model that you are interested in here and I will take a look at its specs to make sure that it should work ok.
One thing to look out for is to make sure it has enough RAM - I'd recommend probably 1GB of RAM, and for running Vista maybe even more.
Also, just a quick note - you don't actually have to use MoI with a TabletPC or a drawing tablet, you can run it just fine on a regular computer too... But a TabletPC is pretty cool to give you a drawing/sketching type feel.
Also, ArtRage (http://artrage.com) is a really great sketching / drawing program that is also very nice on a TabletPC.
1302.3 In reply to 1302.2
THANKS MICHAEL FOR THE QUICK REPLY AS USUALL INEW ID GET HELP IVE GOT A PC THAT IM LEARNING ON AT HOME BUT HAVE SOM EXTRA TIME AT WORK LOL AND NEED TO LEARN MORE AND I THINK THIS IS THE WAY TO GO. THANKS AGAIN MIKE
1302.4 In reply to 1302.3
Hi Mike, no problem!
If you want to browse a few different TabletPC models, you can check out here: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&SubCategory=407&N=2000260407
Also if I remember right, there was quite a bit of TabletPC related information on this site: http://www.tabletpcreview.com/ - they have some discussion forums there that you can browse through to see people's comments on various models.
