Assign commands to buttons?
All  1-3  4
1290.4 In reply to 1290.3
Hi Nick, that's great!
Just a quick overview here - if you look in the \ui sub-folder, the main file that contains most stuff is sidepane.htm .
If you look in there you will find various buttons defined by a
<moi:CommandButton> ... </moi:CommandButton> tag.
The bottom bar is defined by the file CommandBar.htm and CommandBarRight.htm (for the right-side buttons like Options and Help).
To copy a button over, copy an entire <moi:CommandButton>...</moi:CommandButton> tag and paste it into the CommandBar.htm file, before the ending </body>.
Certain buttons pop out one of those little sub-menus, and the buttons inside the sub-menu are defined in another file located in the \commands subfolder. Like for instance all the boolean buttons are in a file under \commands\Booleans.htm, so to copy one of those buttons look in that file for the button definition instead of the sidepane.htm .
Let me know if you get stuck.
> although it goes against the UNcluttered interface you currently have, that I like.
Well, what I was figuring was that it would be totally empty by default, (that will keep the uncluttered-ness for most people), but letting you do something like drag/drop a button to that area, or right-click to get a menu to add a button.
It will be a while before I'll get a chance to work on that though.
Show messages: All  1-3  4
