Assign commands to buttons?
All  1-2  3-4
1290.3 In reply to 1290.2
D'oh! I looked for info like that before I posted, but didnt see it... sorry bout that. That post will do what I want.
But anyway, for those not interested in messing with any behind the scenes stuff, some user defined, OEM buttons would be cool (sure, at the bottom, yeah)... although it goes against the UNcluttered interface you currently have, that I like.
-Nick
1290.4 In reply to 1290.3
Hi Nick, that's great!
Just a quick overview here - if you look in the \ui sub-folder, the main file that contains most stuff is sidepane.htm .
If you look in there you will find various buttons defined by a
<moi:CommandButton> ... </moi:CommandButton> tag.
The bottom bar is defined by the file CommandBar.htm and CommandBarRight.htm (for the right-side buttons like Options and Help).
To copy a button over, copy an entire <moi:CommandButton>...</moi:CommandButton> tag and paste it into the CommandBar.htm file, before the ending </body>.
Certain buttons pop out one of those little sub-menus, and the buttons inside the sub-menu are defined in another file located in the \commands subfolder. Like for instance all the boolean buttons are in a file under \commands\Booleans.htm, so to copy one of those buttons look in that file for the button definition instead of the sidepane.htm .
Let me know if you get stuck.
Well, what I was figuring was that it would be totally empty by default, (that will keep the uncluttered-ness for most people), but letting you do something like drag/drop a button to that area, or right-click to get a menu to add a button.
It will be a while before I'll get a chance to work on that though.
Show messages: All  1-2  3-4
