Bug in rotation!
All  1-3  4-13
129.4 In reply to 129.3
It's when I enter a number with "5" at any place!
A soon as a 5 is typed ---> Extrusion !
On your little numeric calculator inside the"5" works fine and I have a rotation :)
129.5 In reply to 129.4
Do you have any shortcut key listed for extrusion in your moi.ini ?
Also, is your "Num Lock" button engaged?
If your Num Lock is turned off, then your keypad will generate things like Left Arrow, Home, etc.. - maybe you have one of these for an extrusion keyboard shortcut?
129.6 In reply to 129.5
My Num lock is enable else i can't type any number :)
Seems I have no 5 as shortcut (but when I type 5 at the beginning of programm I arrive also at the Extrusion!
It's not the same for you?
Mystery of the technic :D
It's the E see follow....maybe it's a shortcut installed by an another prog or another person who intercept the E
No such trouble as I can use you mini calculator!)
[Shortcut Keys]
Ctrl+A=script:moi.geometryDatabase.selectAll();
Ctrl+C=CopyClipboard
Ctrl+N=New
Ctrl+O=Open
Ctrl+S=Save
Ctrl+V=Paste
Ctrl+Y=script:moi.command.redo();
Ctrl+Z=script:moi.command.undo();
Delete=Delete
E=Extrude
F1=script:moi.launchHelp();
H=script:moi.geometryDatabase.invertSelection(); moi.geometryDatabase.hide(); moi.geometryDatabase.selectAll();
I=script:moi.geometryDatabase.invertSelection();
R=Rotate
Space=script:var selection = moi.geometryDatabase.getSelectedObjects(); if ( selection.length == 0 ) moi.geometryDatabase.selectAll(); else moi.geometryDatabase.deselectAll();
[Recent Files]
EDITED: 20 Sep 2006 by PILOU
129.7 In reply to 129.6
Aha, I can repeat it now that I set a shortcut for E=Extrude.
Definitely a weird bug in keyboard handling, some kind of confusion between numbers and letters, I will look to fix it tonight.
Thank you for finding it!!!
129.8 In reply to 129.7
If the number of keyboard shortcuts increases, please do not loose of sight the fact that there are many users with non-american keyboards. Even the French/French keyboard of Frenchy Pilou is probably different from my French/Belgian keyboard ! ;-)
I know this can cause some issues when assigning hotkeys although I don't know exactly how this can be avoided...
Normaly My key 5 has no short cut installed :)
Complaint
Function "Move object "face to face" (may be not very easy to code but very practical :)
= You clic a face of object one, you clic a face of object two
--> Object one is moving to object two face to face cliked :)
image : More combinaison of blocks
129.10 In reply to 129.9
For now think of it as a "bonus shortcut". You get 2 shortcuts for the price of 1.
This should make it twice as fast to do an extrude, right? ;)
I think the difficult part would be to figure out a good rotation for it automatically.
Just moving something on to the other block should work pretty well already, since if you grab a block near the endpoint of an edge, it should snap on to it and allow you to drop it on the endpoint of a different block. But then you want it to automatically rotate? Hmmm....
You could maybe build a Roman aqueduct with some of those pieces.
129.11 In reply to 129.10
< But then you want it to automatically rotate?
Yes that is the challenge a 3 matrix rotation + Move :)
< You could maybe build a Roman aqueduct with some of those pieces
You don't know Muqarnas ? Mine are free adaptation of it :)
So a Roman aqueduct will be an historical transfiguration scaling :)
http://www.iwr.uni-heidelberg.de/groups/ngg/Muqarnas/basic.php?L=E
A tremendous study of it! http://www.tamabi.ac.jp/idd/shiro/muqarnas/default-.htm
(slide the page if you have some free time :)
Something can help the process :)
3 clicks on a face's object One (a plan defined), 3 clicks for the object Two
Surely more easy to speak than to code :)
EDITED: 21 Sep 2006 by PILOU
129.13 In reply to 129.12
Yes, something where you specify some more reference points could work. I'm going to do some more transform tools such as array in the beta after the next one and I can try to do some orientation tools like this as well.
Show messages: All  1-3  4-13
