Scale Array Problem
All  1-2  3-6
Select all objects + one arbitrary point
Select a curve path if Array along a curve
Apply the Array
Select the objects + all the points but not the curve
Alt + S = Array Scale : enter your datas et voila :)
EDITED: 19 Jan 2008 by PILOU
1285.4 In reply to 1285.3
Quote "make sure to include a single point object"?---all objects + "one arbitary point"?
This "point" I guess is my problem. How do I create it?
(Sorry if the question is a bit dumb--probably kick myself, again, when explained!)
1285.5 In reply to 1285.4
Hi Brian, create the point object by going to Draw curve / More / Point.
The point should be placed at the spot that you want the scaling to happen from, select the point along with your objects when you array them.
See here: http://moi3d.com/forum/index.php?webtag=MOI&msg=275.109
for the original ScaleArray post that has some more details and an example image.
Let me know if you are still stuck.
1285.6 In reply to 1285.5
Thanks Michael. I was about to post that I had found it.
Thanks to all.
Show messages: All  1-2  3-6
