MoI 1.0 is released!
 1-7  …  28-47  48-67  68-77
1284.68
Michael G.
I finally purchased V1 tonite! Very proud to have been a part of the beta testing and looking forward to beta testing future versions.
Also proud to contribute to the V1 release by purchasing it.
Your forum also has been great to deal with also.
I truly cannot say enough great things about MoI3d. It makes it a delight to design again!
Thanks again Michael G!
Michael Tuttle
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
1284.69 In reply to 1284.68
Thanks very much for your order Michael, I really appreciate it!
I am very glad that you enjoy using MoI, that means a lot to me! :)
- Michael G.
1284.70 In reply to 1284.40
Hi all,
in Windows Vista I've found the ini file and license file under:
C:\Users\ [your login name] \AppData\Roaming\Moi\
1284.71
Bloody typical! I have just ordered Rhino because I was fed up with MOI not working in single view mode
under Parallels. I have just returned to the MOI site after some time and see that it's released!
I downloaded the demo of MOI v1, only to find that now it
runs perfectly under parallels, single windows too!! Grrr! Now I don't know if I can afford it.
Mind you, it's almost worth it just for the lovely export. Also, of course, I have T-Splines for Rhino which
is brilliant for a sub-d man like me.
Anyway, if anyone's interested, MOI runs lovely under parallels on a mac!
I will start saving immediately.
Good luck
Roger
1284.72
Congrats for the release Michael, I recently jumped aboard the final release and hope the best for MoI.
Erwan
1284.73 In reply to 1284.1
Hi Micheal
well congratulations on the relase of the software.. i have already sold your software to about 5 people my workplace, when i present something designed in MOI, they all come and ask where i designed my presentation.
also i read you may want to offer 1 year licenses..
just thought i would report a small bug on your trial calculations... last night i had 21 days left, this morning i changed my ms config, -> tools -> Disable UAC... and now my license says
" Error, the trial period of this evaluation has been manipulated"
well, i am buying the software next month, so its not a problem for me, however i just thought you would need to fix this for the 1 year copy..
thanks for the great software and cheers.
Anthony
1284.74 In reply to 1284.73
Hi Anthony,
Thanks for letting me know - it looks like the trial manager thing that I use has just come out with an update that should fix this problem when switching UAC off, I'll see if I can get an updated trial version out pretty soon.
I'm not quite sure if it will solve it on your system where the expiration thing got triggered already (maybe it will), but at least it should help prevent it from happening to other people.
Thanks very much for promoting MoI around your workplace, I really appreciate that a lot!
1284.75 In reply to 1284.40
Portable MOI3D on USB v2
I just tried to use the portable MOI on a 2gb usb flash drive. With the 3 files it asks for a dll - put that on the stick and then it asks for another - copied all of them over still doesn't work. Are there new instructions for v2 to run from a flash drive.
Gary
1284.76 In reply to 1284.75
Hi Gary, actually the instructions for running MoI v2 from a USB stick are the same as MoI v1...
But there are a lot more than 3 files involved - you have to copy the entire installation folder including all sub-folders (like \ui and \commands) over to the USB stick.
After that you can run moi.exe directly from the USB stick, but if you are running it on a different computer it won't find your license key info and it will ask you to enter in your license key.
If you want to avoid entering in your license key, then you would copy the license.key files (and also moi.ini if you want to have all your settings with you) over as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1284.40
If it's asking for DLLs and not even running, that means that you have not copied the entire installation folder over to start with.
1284.77 In reply to 1284.76
Good to know - Thanks
Show messages:  1-7  8-27  28-47  48-67  68-77
