Let's see - what else should I mention...
The 1.0 release is the same as the last beta+patch, except all the expiration is of course removed and there is a new dialog on startup for entering in your license key, which you will receive through e-mail when you order.
Also thanks to Tony Kluever, a German translation of the help file is now included with version 1.0, I will be making a German PDF and on-line versions shortly.
I also tweaked the installer a little bit to use MoI logos instead of generic "install" graphics.
When you order, there is an option for buying a CD. This isn't really a whole box or anything, it is just a very basic CD sent in a little cardboard envelope that has the moi_v1_setup.exe (same as the download) burned on to it.
