Lock object select
All  1-3  4-6
1253.4 In reply to 1253.3
Hi Marco - I'm still not sure if I understand your question. Normally you would want to lock everything _except_ the objects that are selected, so the selected objects will still stay normally active.
That is done by the "LockUnselected" script on that page.
If you want to lock only selected objects, you should be able to do that by this modification to that script:
script:var objs = moi.geometryDatabase.getObjects(), locked = moi.geometryDatabase.createObjectList(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.selected ) locked.addObject( obj ); } locked.lockSelection();
Please let me know if that is not what you are looking for.
1253.5 In reply to 1253.4
Hi, Michael
It is itself actual this script.
But unfortunately I is not in a position of to change it.
You could help me
1253.6 In reply to 1253.5
Hi Marco, I did change the script above to do the reverse of the one that was on that page - that is to lock selected objects instead of locking unselected objects.
I'm sorry I don't understand what you want it to do instead? Can you please describe more about what you want it to do?
Show messages: All  1-3  4-6
