Blend tool for curves ?
125.1
Hello,
Question : Does the Blend tool work only for surfaces or is it normally also possible to blend the end of two open curves (that do not belong to any surface) ?
If I use the tool on two such curves, nothing happens. Is that a bug ?
Workaround for this is to extrude both curves, blend the surfaces, select the new edge curves and delete all the rest...
Schbeurd
125.2 In reply to 125.1
> Is that a bug ?
Bug is such an unpleasant word... I prefer to call this one an "unfinished area" :)
It is intended that it should work as you wanted it to, just the work to do it hasn't happened yet. Probably it won't be done for the next beta (which I'm hoping to put out pretty soon), but maybe the next one after that.
125.3 In reply to 125.2
Thanks for the info.
I was just wondering because when I tried to do this, the leds on my hard disk were flashing so I tought there were some calculations going on but nothing happened...
For what concerns the use of the word "bug", we'll say that it's due to my bad english ! ;-))
