Closed loft
All  1  2-5
122.2 In reply to 122.1
There isn't a way to do it with loft right now, but it can be done with sweep as a workaround right now.
In the attached example, I created 2 rail curves along the top and bottom by using Draw curve / Freeform / Through points. Then select the 4 profile curves, and do a sweep with those 2 rails.
The resulting shape has a couple of shading glitches - you can fix these by going to Options and turning on "Add detail to inflections". I'm hoping to make this on by default after I have a chance to tune up the meshing a bit.
122.3 In reply to 122.2
Yep,
The workaround works find and will be OK in most of the situations I can imagine...
Thanks ;-)
BTW, is there any limitation in the number of curves you can use as profiles ?
I think it's time to start a "Tips and Tricks" topic in the forum... :-)))
122.4 In reply to 122.3
Nope, you should be able to use as many as you want.
But sometimes it can be a little frustrating if you try to build too much of a giant detailed thing just in one single enormous loft or sweep operation. It tends to be a bit more strategically helpful to do things in more managable pieces.
I mention this because sometimes I see people trying to create something like an entire car with just one loft with a huge number of sections.
122.5 In reply to 122.3
< I think it's time to start a "Tips and Tricks" topic in the forum... :-)))
Done :-))) :-))) :-)))
Show messages: All  1  2-5
