New Dec-28 beta now available
 1-4  5-24  25-30
1217.5
Happy Hollydays
1217.6
Hi all,
This is quick and rough modeling with new beta of MoI.
One question. I'd like to use shortkey same as Rhino's alias command. Can I set keys for commands in MoI like as 'SV', not just like V or 'Shift+V' ??
For example, in my rhino, a alias is setting as 'SCTF' is for ScreenCaptureToFile. Is it possible in MoI?
momso
1217.7 In reply to 1217.6
Hi Momso, sorry no multiple keys will not work. MoI doesn't have a command-line interface like Rhino, which is one reason why you can do single-character (without enter) shortcuts inside of MoI.
In the future I would like to work on this some more to make multi-character shortcuts possible, but right now it will not work.
Just a quick note on screencaptures, see here: http://moi3d.com/forum/index.php?webtag=MOI&msg=1049.5 for a script for how to do a screen capture in MoI at a size larger than the current displayed viewport.
1217.8 In reply to 1217.3
Hi Marc,
> I understand that Moi's primary focus is 3d but over time I discovered that it's
> drawing engine is also superior for creating 2d geometry.
> No other applications is as responsive, fast and intuitive.
I'm glad that it is working well for you in 2d as well!
I do intend to expand the 2d capabilities over time as well, so this path should improve over time.
1217.9
oh great update! and on the features I am using the most right now too!
thanks!
Question: Is heaving multiple number of images, lets say one in front view and one in right view; does it increase the amount of memory consumption for the video card? Even if using only one view at a time?
1217.10
Thank you for this latest and maybe last beta release :)
And finally.. have a great New Year and thanks for all your great work on Moi3D now in 2007, next year is gonna be a interesting one for sure. "The Year of Moi" as it'll be called will be printed in the historybooks for future generations to read. hehe
/ Magnus
1217.11 In reply to 1217.9
Hi Val, I'm glad the update is helpful!
Actually using only one view at a time (with separate images in each view) should help conserve video memory.
There is stuff built into the DirectX system so it can manage these textures that reside in video memory, and if video memory is getting cramped, it will chuck them all out to main system memory and then only load back the ones that are actually needed dynamically.
So the one for the non-active view will get chucked out in that situation and only put back in when it is actually used when that view is displayed later.
If you have a pretty low amount of video memory you should probably not try to use very high resolution images though.
1217.12 In reply to 1217.10
Thanks Magnus and everyone else! Happy New Year!
1217.13
Thanks Michael. And happy new year in 2 hours 1 minute!
1217.14 In reply to 1217.3
>>>You can now hold down shift+control when selecting to make the initial click ignored and force a window type selection instead.
>This is a great idea!
>if only other applications would behave like that.
Hi Marc, you can do the same in Rhino using Alt key and dragging a selection window. -Petr
1217.15 In reply to 1217.1
MoI seems to be faster while updating a view! Some improvements in a display engine?
Although, the executable file moi.exe put on weight during Christmas... hehe...
Petr
1217.16 In reply to 1217.15
Hi Petr!
Hmmm.. I don't really remember any changes that would effect this.
Well it was so skinny that I figured it could use some fattening up!
That's due to the new icon - it includes a large 256x256 image in it for Vista, stored uncompressed so as not to confuse Win2k.
This one also has the curve fillet bug that you reported back a little bit ago fixed.
1217.17 In reply to 1217.16
Maybe, a vacation and ice skating relaxed my eyes so everything seems very quick now :)
>>Alt+Ctrl+drag a window
Idea: Currently, there is no way of deselecting an objects by dragging a window. Alt+Ctrl+drag a window could do this(?).
Petr
1217.18 In reply to 1217.17
Hi Petr,
Right now Alt+Ctrl+drag inside of a viewport will do a zoom (move up and down). This is one of the alternative view key/mouse combos that are enabled to make MoI friendlier to people who spend most of their time in some other package, I think this one is a Maya shortcut...
Any idea of a different combo?
Currently a bunch of key combos are taken up for this kind of view manipulation compatability.
1217.19 In reply to 1217.18
ehm... sorry, Michael, I meant a new "Shift+Ctrl+dragging selection window" mechanism actually. Would it be possible to add that second function (deselecting selected objects by dragging a selection window) to this shortcut? -Petr
1217.20 In reply to 1217.19
> mechanism actually.
Right, but that combo that you were talking about Alt+Ctrl is already in use for zooming (for Maya compatibility).
I mean that if you hold down Alt+Ctrl and left drag up and down, right now it will do zooming.
To make it do deselection instead, I would have to remove the zooming function from that key combo and lose the Maya compatibility...
It kind of makes me uncomfortable to have so many of these different multi-key combos... It might be nice if there was only one way to force windowing and then some kind of option that could be triggered (pressing d??) to tweak it for deselection instead... But nothing really great immediately comes to mind.
Edit: Hmmm, maybe if you use Shift+Ctrl to initiate windowing, then let go of shift and keep only control down to make it do deselection? Do you think that is too tricky? The selection preview display will probably help, since if you forget which one it is you can just hold shift by itself (after the initial window has started) or control by itself until you see that you have got the right one.
EDITED: 4 Jan 2008 by MICHAEL GIBSON
1217.21 In reply to 1217.20
Yes, I know. It was a typing error. I didn't want to redefine that multi-key combo for zooming at all.
Generally speaking, why windowing cannot deselect a selected object(?) When I pick the selected object it gets unselected. So why couldn't dragging selection window (both solid and dashed area selection box) deselect previously selected objects?
..or....might it be possible to script an additional type of windowing and users could choose their own shortcut to initiate windowing which would work like - select unselected, deselect selected objects?
I think so...it would be for virtuoso only :)
Petr
1217.22 In reply to 1217.21
Hi Petr,
It's because of targeting multiple objects - sometimes when you do a window, you may want to do several overlapping windows to help you build up your final selection.
If previously selected objects inside the window became unselected, it would interfere with this - objects in the areas intersected by multiple windows would keep flipping their selection state instead of all staying selected.
This is probably not too hard, I can give it a try when I get back.
1217.23 In reply to 1217.14
Hi Petr,
Thanks for pointing this works also in Rhino.
Actually I found that in Xara (another well programmed software but for 2d vector illustration) there's a similar behavior, while pressing shift to add objects to selection, it ignores background objects when dragging a marquee.
It's small details that makes great tools!
Regards,
Marc
1217.24 In reply to 1217.22
Ok. That sounds reasonable to me.
And how do you feel about the possibility to pass the location of moi.ini file as an argument to moi.exe? I know the people who prefer different color settings when working daytime versus at night or it would be useful to keep the complete default look...
I also wish to have a separate undo/redo stack for "viewport changes" like in Rhino (Home/End).
Petr
Show messages:  1-4  5-24  25-30
