Moi3D & Free Ai without any MCP !
 1-5  6-25  26-45  46-50
12142.46 In reply to 12142.44
@ Michael
I suppose the slice parts are for communicate more easily with the user...
Ai Front view proposal (whitout sketch so pure Ai imagination justified )
I have given it the 3/4 bottom sketch, its first blue print and the realist view generated)
Fichier 3dm when new curious problem of importation will be resolved!
EDITED: 27 Nov 6:40 by PILOU
12142.47 In reply to 12142.46
Frenchy you can clearly see that the left front of the result sketch is total rubbish. You can’t get sensefrom nonsense.
12142.48 In reply to 12142.47
@Bin
I am not yet qualified for see if it's pure rubbish or not when i read that...
Aesthetic approach and surface continuity
Fenders and front wheel arches: a pronounced, taut curvature that extends the dynamic flow of the profile, complementing the wheel arches already established in the wireframe base.
Hood and low-slung nose: a gentle downward slope toward the front, featuring a subtle central bulge and fluid edges that capture the momentum of the original sketch.
Lighting signature and air intakes: slim, integrated headlights that follow the tension lines, paired with sculpted lower air intakes to provide visual balance with the rear diffuser.
NURBS surfaces (sculpted hood with integrated front fender curvature + lower splitter) and guide curves (leading edge of the nose, central spine, and left/right front wheel arch arcs).
NURBS surfaces (Entity 128): sculpted hood with integrated front fender curvature and lower splitter.
Closed trimming curves (Entity 126):
Front headlights (left and right): profiled closed loops projected flush against the fender curvature, ready for "Trim" or "Project" operations.
Side air intakes (left and right) and central intake: closed contours prepared for cutting or extrusion between the nose and the splitter.
Hood air extractors (left and right): longitudinal loops aligned with the channels on the hood.
Structural guide curves (Entity 126): leading edge of the nose, central spine, and front wheel arch arcs.
Sculpted front hood with integrated fender curvature + lower aerodynamic splitter.
Leading edge of the nose, central spine, left/right front wheel arches, closed contours for the front headlights, side/central air intakes, and hood extractors.
Curious some days Gemini seems have different teams!!!
A day no problem for make something another day ask to do exactely the same thing is impossible!
I ask to it...different teams ?
<< Yet I swear that’s not true! :)
<< There hasn’t been a change in the team—I am an AI system, and this behavior is simply a result of how the tools and output formats are made available within this session.
For user result is same than different teams! :)
EDITED: 27 Nov 10:49 by PILOU
12142.50 In reply to 12142.48
Well yes, and this is the root of the problem.
You are quick to post any results you generate using AI, and you seem to assign value based on it having required little effort.
When I ask what does that have to do with MOI you post obviously garbage models like this:
You post about how wonderful the guide steps are even for novice users and fail to post any result in MOI from actually trying to use them.
In short, you post big piles of automatically generated junk, declaring that it's all great.
It is not hard for me to understand that users who are operating as skilled craftsmen find this to be both annoying and ever more straying into being actually offensive to their own values.
So please Pilou, stop posting AI related content on this forum.
Previously I was going to make a separate section for you to post AI slop in but I'm thinking now that is not the best because other topics using AI as a productivity enhancer to help with real work are not causing any problem here.
It's just you posting AI slop that is the problem.
So stop doing it please.
Thanks, - Michael
Show messages:  1-5  6-25  26-45  46-50
